Question about ASUS P5RD1-VM Motherboard
Problem with replacing the motherboard and keeping my old hard drive
I just replaced my motherboard with brand new one and everything seems like it is working fine but it just won't read my window XP installation CD.
I've set CD-ROM drive as 1st boot device in BIOS.
And I do not have the back-up disk.
  • 383 Answers
Windows XP questions and answers CH000635, How to get into Windows XP recovery console without a Windows XP CD. CH000646, NTOSKRNL.EXE is missing or corrupt.
How to create a boot disk. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
How to erase my hard disk drive and start over. If you are running or plan on installing Microsoft Windows XP please see ... First, we recommend that all users wanting to simply install Windows NT use the .
How to use the Windows recovery console. Place the Windows CD in your computer and boot from the CD. ... To repair a Windows XP installation using recovery console, press R.
Good Luck, Please dont for get to Vote/Thank You.
Posted on Dec 23, 2007
Replace hard drive motherboard
Before you start replacing drive you need to ask yourself if you are trying to replace a bad hard drive and just want to start with a clean install of the O.S. OR are you replacing your hard drive with a bigger one and wish to keep your installed programs, data and documents. If you want to keep your data and documents you need to know how to save the Files and folders on your computer to a CD, DVD or a USB hard drive. Just replacing the hardware involves unplugging all cables from computer after shutting it down. Then opening the case and unplugging the cables from the hard drive and then remove the screw(s) retaining the hard drive. Remove the old hard drive from the case and replace it with the new one, replace screws and plug cables back up watching that that the connectors are correctly aligned with the key(s) on the hard drive's sockets. Replacing the Hard drive also involves installing the O.S. and all your programs and applications on the new hard drive. You can find a lot of information in the internet about this.
Oct 21, 2013 | Gateway SX2855 Case
Need nec versa e 6000 motherboard faulty . where i can buy the motherboard?
it is not worth it to purchase a new motherboard for around 200$ when you can buy a brand new computer for just a little bit more.
You can have your files moved from the old hard drive to the new laptop by a professional or you can do it yourself if you aren't a complete dummy with computers.
To do it yourself you would need to first remove the old hard drive from the old computer ( NEC ) and then buy a external hard drive case for it that fits to it - there are 2 sizes, 2.5" and 3.5", probably 2.5" hard drive and then there are 2 types of connectors, IDE and SATA. SATA has a flat connector, and IDE has around 40 metal pins sticking out of it.
buy the appropriate USB caseing for it and then connect it to your new computer, you can transfer your files from it to the computer, after you have done so, you can keep the old hard drive as a external hard drive, for backups for example.
Jan 04, 2011 | NEC Computers & Internet
Hi there the computer will stay on for about 10 min or so and then lock up and mouse and keyboard lock please help brand new computer did it the day i got it
Hi you should take it back to the place of purchase before doing anything otherwise you might lose any warranty you have on this new computer
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors automatically fix any corrupt files on your hard drive then defragment your hard drive you have to keep a computer very clean & free of dust and give it regular maintanance
hope this helps
Dec 14, 2010 | Acer Computers & Internet
My monitor keeps blacking out every now and then. I have checked the connection between it, and the computer, and everything seems to be fine. I don;t understand why it keeps blacking out.
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
Nov 22, 2010 | Computers & Internet
Acer vt7500 with a s88m motherboard and xp pro The hard drive(40gb) is failing and I would like to know what I could replace it with (ie. largest size) and install xp. I do not need to save the old...
Your 40GB drive is an IDE ("Integrated Drive Electronics") drive.
The largest IDE drive ever manufactured is 500GB.
However, some motherboards do not support drives larger than 320GB.
Some disk-drives (Seagate/Maxtor) come with a CD-ROM of "tools" that enable you to copy "everything" from your "old" drive to your "new" drive.
Oct 26, 2010 | Computers & Internet
My a785E Biostar MB is brand new it worked for about a week and then my operating system now fails to load. cant even load a new op on a diffrent drive. I reset the cmos and nothing stiil wont load...
good luck
Aug 30, 2010 | Biostar A785GE Motherboard
After replacing a new hard drive my computer now failed to boot, it keep restarting. I then replaced it the old hard drive again and the same problem as above. Please help.
Hi
it seems that you know what you are doing -
it seems that the problem is with in the connections
please recheck the connections
the best way is
1) unplug the HDD (hard disk) Power and Data cable
and turn on the PC -- check whether its working (or is it rebooting/restarting)
if its restarting then there is something wrong somewhere else
here you said you just replaced the Hard drive --
there are 2 IDE Slots - check connecting the Hard drive to IDE 2
and use the same Data cable for CD/DVD and HDD --
2) check the RAM Connection unplug and replug (it might be loose)
but be careful Power supply shout be OFF while playing with Connections
3) Check the Connection to the board -
don't worry it will work
Jan 03, 2010 | ASUS P4P800-MX Motherboard
System crashes completely. just freezes and never recovers. for some odd reason, when i try to run the windows repair, it crashes as well giving me the blue screen of death. i have three other hard drives:...
You are probably correct in thinking it a motherboard problem, its sounds like the disk controller on the motherboard id faulty.
There are a huge range of motherboards to choose from.
The mounting holes on the motherboard will match the desktop mounting plate, these are standard configurations.
Stick with the well known brands and with the functions that suit your requirements.
My choice of brands are Gigabyte, Intel, MSI.
If you are into gaming and video editing etc. go for a motherboard without a built-in graphics card and purchase a separate high end graphics card.
Nov 14, 2009 | Acer Aspire M5641 PC Desktop
Hard drive replacement
SATA drives are the latest hard drives available nowadays. You could try going online and checking other sites that could still have an IDE hard available for sale.
Jan 02, 2008 | Samsung SpinPoint SP8004H 80 GB Hard Drive
ASUS P5RD1-VM Motherboard Logo
161 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
