Question about HP Computers & Internet
Not functioning at all. could it be because of improper shut dow due to system freezing??n
  • HP Master
  • 8,404 Answers
Can you get into the device manager to check for troubles? These are regular Microsoft type wire devices?
Unplug and replug them in ... if you see trouble in the device manager, delete the entries if you can and let Windows reinstall them. You may have to use Safe Mode.
And, there is a good possibility none of this will work. If tht is the case, let me know and we will try something else.
a
Posted on Oct 02, 2009
Dow mixture is not working
Engine Problems - HowStuffWorks
auto.howstuffworks.com/engine3.htm
Engine problems are often due to a bad fuel mix, lack of compression or lack of spark.... How Car Engines Work ... If the wire is cut or missing, or if the system that sends a spark down the wire is not working properly, there will be no spark.
[PDF]Product Safety Assessment Toluene/Xylene Mix - The DOW ...
www.dow.com/webapps/lit/litorder.asp?...
Dow Chemical CompanyOct 27, 2012 - Toluene/xylene mix should not be sold to consumers and not be used in pesticide ... transportation vessels (tank cars, tanks trucks, and barges), from emissions ... program for employees and appropriate work processes and.
How to Use an Auto Scan Tool - Popular Mechanics
www.popularmechanics.com/cars/how-to/a3293/4267896/
You're tooling down the road; it's a beautiful, sunny summer day, and to top it off, ...most modern fuel-injected cars and trucks are run by one or more computers. ... days because this computer system self-corrects the fuel mixture and ignition at ... Plug your scan tool into the standard OBD II connector under the driver's side ...
HHO car adaptation - Instructables
Dec 16, 2015 | Cars & Trucks
Tip
Failing emissions testing due to high NOX (oxides of nitrogen)
I have seen several people posting emissions failures due to high NOX (oxides of nitrogen). Nox is created when the engine's internal combustion temperature gets to high.
Two reasons this can occur is improper coolant levels and a malfunctioning egr system. The egr system injects exhaust gas from the exhaust and uses it to line the cylinder walls.This in turn reduces the combustion chamber size and internal combustion temperatures. Ultimately this reduces the amount of NOX created. These systems functioning properly can be the difference in passing or failing your emissions testing because of high NOX ppm.
on Jun 18, 2010 | Chevrolet 1500 Cars & Trucks
Mark 1 fridge is freezing everything in the bottom. how do we fix it? the controls are turned way dow
chech the fan near freezer running properly,no items against its air flow,,,reset goods in frige due to low space
Jan 22, 2015 | Refrigerators
What causes a water cooler to freeze up around coils?
It is dues to improper air flow. which can be caused by multiple factors.
1. Return Air Vent is blocked
2. Evaporator Fan not working
3. Improper Thermostat.
Is the water cooling Ok. if the thermostat is not ok, the water might be really freezing.
Nov 05, 2014 | Water Filters & Coolers
I have a 2004 grand cherokee jeep limited edition the back window was broken into, and maybe they tried to do somehting to shut down the alarm system, (we dont know)..battery had to be...
Diagnosing an electrical issue is never easy or cheap, sorry. When fuses blow, it is due to an improper flow of electrons. When relays go bad, it is due to overheating(which is often due to an improper flow of electrons). The BCM(Body Control Module) could be to blame... let us know how it works out =D
Feb 01, 2014 | 2004 Jeep Grand Cherokee
98 Cavalier. The compressor starts than shuts dow.
I take it that you are talking about the A/C Compressor? If your clutch on the a/c compressor clicks on and off constant this usually means you are low on 134A and possibly have a leak in the system eventually the compressor will not operate due to no pressure at all in the system
Mar 19, 2011 | 1998 Chevrolet Cavalier
NTLDR is missing Press Ctrl+Alt+Del to restart this is what my screen goes to, how do i fix this?
The operating system files are been corrupted due to improper shut down you need to reinstallt he operating system
Sep 26, 2010 | Computers & Internet
The frigde is turned dow but still freezing all
your cold temperature control is bad, not shutting the unit down when the temperature is correct. needs to be replaced.
Mar 23, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Problem with google chrome
This is probably due to improper installation of the program. Choose the correct version of software in accordance to the Operating system for proper functionality.
Dec 18, 2008 | Facebook Social Network
My xbox keep freezing
xbox freezing happens due to improper cooling
try t add extra fans
Jun 21, 2008 | Video Game Consoles & Games
Computers & Internet Logo
19 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
