Question about Acer Aspire 5100 Notebook
DVD player stopped working
I have a Fujitsu C2330 Lifebook that the DVD player stopped working. When you go to "My Computer" it does not even show being in the list of available drives to go to.
Any help would be appreciated
  • tapfla Oct 02, 2009
    When you put in a new CD it starts to spin but then stops. You can here movement happening but not for very long.
    Problem Solver:
  • 11 Answers
I think its power got cut off from the mother board or hard drive
Posted on Oct 02, 2009
Ram install for fujitsu c2330
Hi there. Power down and remove the battery from your notebook. Look along the bottom of the laptop for a plate with slits for air circulation and a label - something like Memory, RAM, C/M. Undo the screws and remove the plate. You will see RAM that looks almost identical to the RAM you have purchased. If it does not, you have the wrong plate. Put it back in and try a different one. Once you can see the RAM, you will notice a pin on each side of the stick. Push both of those towards the outside of the laptop, and the stick of RAM will "pop" out. Pull it straight out along the same angle it currently sits at. To install the new RAM, push the ram in, aligning it the same way the old RAM came out, and then push it down towards the ground until it clicks. Alex
May 30, 2011 | Fujitsu LifeBook C2330 Notebook
How do i use recovery cd's if i have no cd rom drive? i have an external cd/dvd drive plugged into usb port but the fujitsu 1510d lifebook does not recognise it? thanks dave
When you boot your computer, start up your BIOS, then under the boot menu, make sure USB is listed as the 1st option.
To log into your BIOS, press the "Boot Option" key. It might be F1, F2 or Delete
Feb 28, 2011 | Fujitsu LIFEBOOK P1510D Tablet PC
Screen is black with flashing cursor
Try to make sure that the first boot is set to CDROM.
May 02, 2010 | Fujitsu LifeBook C2330 Notebook
Fujitsu Lifebook P1120 Won't Boot To CD\DVD
Fujitsu seems to have secretly added a Hardware black list for Booting USB DVD-rw.CD-rw drives.
I have a Stylistic ST5032D slate.
Your either going to have to buy fujitsu's over priced external drive or buy fujitsu's over priced dock.
Or What I do is Bought WinImage or any other software that allows writing a ISO image to USB flash drive, this should almost always work.
I had to install Windows 7 on my tablet this way.
Choose your poison.
Good Luck.
Oct 03, 2009 | Fujitsu LifeBook P1120 Tablet PC
I need to replace my internal dvd drive on my fujitsu c2330 laptop computer
gently pull out dvd unit,disconnect connections,find new dvd by using model number
Sep 23, 2009 | Fujitsu LifeBook C2330 Notebook
What is the ac polarity of a fujistsu lifebook c2330?
In household and commercial electronics 110-125 AC has no polarity unless there is a safety ground, in which case the green safety is connected to to the white wire via earth ground. Black is "hot" meaning if you touch it you will feel a shock because your body connects the circuit to ground. A laptop operates on DC power delivered from an AC-DC converter usually around 20 Volts dc and 3.5 Amps, and charges the battery as well. Polarity of your computer is positive tip meaning the fat part of the plug going into the jack is ground, or negative, and the center is positive. I hope this helps.
Jul 05, 2009 | Fujitsu LifeBook C2330 Notebook
Fujitsu Lifebook C2330 Monitor dark
Your LCD backlight is not working. It is fixable but it is not a repair I would recommend to the typical user. The reason is that you have to disassemble a fairly good portion of the laptop to access the light source and/or the electrical components that control it. If you have excellent attention to detail, patience, experience with the disassembly and handling of electronics and the tools then give it a try. It is also important to also realize that by doing it yourself you risk the real possibility of damaging your laptop beyond economic repair then it may also be worth a try. Otherwise I would strongly suggest you take your laptop to the local authorized repair shop.
Feb 03, 2007 | Fujitsu LifeBook C2330 Notebook
Acer Aspire 5100 Notebook Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
