Question about Brother Office Equipment & Supplies
Black line off center of printed page
Used white out on original. When copied, black line appeared. Believe white out was not completely dry and is causing black line
    President:
  • 3,085 Answers
Open the doc feeder and clean the scanner glass with alchol
Posted on Oct 02, 2009
  •  Exinco
    Exinco Feb 12, 2014
    hi, how to open that scanner glass?
Sharp AL-1631 Copies has begun to print verticle lines on page.
if the drum already been scratched out,so there is no solution to repair it,u have to change the drum.before change the drum check the copier glass surface if any dry up material,wipe it with dry cloth.
Dec 09, 2008 | Sharp AR-5320 Black and White Copier
Thin black line on Xerox 4011 laser printer
Does the same thing occur with a different document.. Because it is not repetative, it leads me to believe the line is being drawn at the direction of the software. Try printing a test page, and see if the line appears. If not the issue is from within the word processsing software. It almost sounds like a legal template for a pleading..
Nov 21, 2008 | Computers & Internet
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
Black Line Down Center of Page
I had the same problem. I cleaned the strip above the glass and this fixed the problem. Hope it helps!
Feb 14, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Printer problem
Does the line appear while copying or printing ?
To isolate the issue try to print a self test page :
1. Press and hold the Cancel button and then press the Start Copy Color button.
2. Release both buttons. The self-test page prints.
If you see lines on the test page then the issue is with the cartridge or cartridge contacts. Clean the cartridge and cartridge contacts inside the printer.
rRemove both the cartridges. Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts.
The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth. Gently wipe the contacts, from the top to the bottom.
Reinsert the cartridge and print. If the issue issue persists replace cartridge(s).
If you do not see lines on the test page. Place the same test page on the scanner glass and make a color copy. If the lines are on the copied Image the issue is with the scanner glass.
clean the scanner glass :
Clean the glass and scanner backing
  1. Turn off the all-in-one.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the all-in-one.
  4. Raise the lid.
  5. Clean the glass with a soft dry cloth, or a sponge slightly moistened with non-abrasive glass cleaner or water. CAUTION: Do not use abrasives, acetone, benzene, or carbon tetrachloride on the glass; they can damage it. Do not place or spray liquid directly on the glass; the liquid might seep under the glass and damage the device.
  6. Dry the glass with a chamois, cellulose sponge or soft cotton cloth to prevent spotting.
  7. Clean the white scanner backing with a soft dry cloth or sponge slightly moistened with water, and allow it to dry.
Try a blank copy
  1. Plug the power cord back into the wall outlet.
  2. Plug the power cord into the all-in-one.
  3. Turn the power on.
  4. Close the lid; do not place any paper on the glass.
  5. Load paper in the paper tray.
  6. Do either of the following:
    • Press Start Copy Black to start a black-and-white copy job.
    • Press Start Copy Color to start a color copy job.
  7. If the output is a full/half-black page, or has vertical black lines, the product needs service or contact HP for in warranty replacement.
Thank you .
Silan
Dec 20, 2007 | HP Photosmart C3180 All-In-One InkJet...
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
424 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
