Question about Refrigerators
Water and ice in the refrigerator part. I don't see a drain, or where it comes in (presumably from the top freezer).
  • 4,070 Answers
Yes, It may be behind the cover in the freezer on the rear wall. It is probably covered in ice right now. On some you can see the drain without removing the rear cover.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Oct 02, 2009
Whirlpool top freezer refrigerator has water in bottom refrigerator
when the machine goes into defrost the heater in the freezer comes on and melts all frost off of the evaporator coil,the water goes down a drain line down to where the compressor and condensor coil is and there the water evaporates,your drain is blocked so the water can't drain down and leaks into the fridge section.when you write looking for answers you have to send the model number off of the machine,if the freezer is on top open the fridge door and look on the left side wall up near the ceiling and there should be a tag with model number,unplug the fridge or shut down the cold control,remove everything from the freezer and remove the back inside wall of the freezer,with a hair dryer melt out all the ice under the evap coil,i use a steamer to clean out the drain,if you don't have one you can try a turkey baster or anything that will push air or water down the drain hole,when you think the drain is clear pour hot water into the hole,if it drains down then it's clear,if not keep hitting it,you can also heat up the back center wall and ceiling in the fridge section to help melt out the ice.there's also a heater probe you can buy that you stick into the drain and it raps around the heater,when the heater comes on the probe heats up and keeps the drain from freezing up,you can also use a ground wire from an electrical piece of house wire or from a cable wire,cut a piece around 6 inches,stick it into the hole and rap the end around the heater,if it's a glass heater connect the wire to the metal in front of the heater,if 6 inches is to long trim it down a little so it fits.good luck,if you need anymore help let me know.
Jun 19, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
The bottom of my fridge is filling up with water. I noticed its leaking from the top back of my fridge. Someone suggested its a condensation problem.
Check the drain tube that runs from the freezer to the drain pan, my guess is that its plugged with goo, connect a bulb like you use to asperate a child nose ect and see if it plugged, you can use hot water from the drain pan end and force the water up forcefully to break it loose or you may have to remove the bottom pan in the freezer and clear the drain. If its got ice built up blocking the drain then use hot water to cut the ice and clear the drain first if possible, then the water pan will catch it, but don't let it over flow.
Jun 26, 2011 | Kenmore Top Freezer Refrigerator
Water is leaking into the refrigerator from the freezer it seems to be worse when the ice maker is on
if it's worse with the ice maker on i'd have to say the ice maker is leaking but normally the water is from a blocked drain in the freezer.unplug it,remove everything out of the freezer,pull off the inside back wall of the freezer,melt out all the ice with a hair dryer,next you'll see a hole under the evap coil,that's the drain,you have to free it up,i use a steemer to blow down through the drain but if you don't have a steemer keep heating up the area where the drain hole is,you can try using a turkey baster to blow through the drain,when you think the drain is clear pour hot water into the drain hole,if it goes down you're done,if it doesn't keep heating it until the water drains down the hole.also open the fridge door,in the top of the fridge in the middle of the ceiling and where it touches the back wall you'll see a mold,that's also the drain,heat that area up with the hair dryer to melt out the ice in the drain.the problem is slime builds up in the drain,when the fridge goes into defrost the heater comes on and melts the ice off of the evap coil and the water goes down the drain and into the drip pan on the bottom of the fridge,your drain is blocked and the water is leaking into the fridge,the drain has to be cleared.good luck with your machine.if i can help you with anything else let me know.
May 11, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is coming down thur the 2 vents in the refrig, and the freezer has ice on the floor.
The defrost drain line in the freezer has frozen closed with ice.
Defrost the drain hole with hot water or a hair dryer.
Turn the refrigerator OFF before doing this.
Apr 04, 2011 | Whirlpool ET1WTKX Top Freezer Refrigerator
Water dripping into the refrigerator area from the freezer
Means you have a clogged or iced drain. Remove rear panel in the freezer and pour hot boiling water into drain. Inspect to ensure it is not iced. Keep pouring hot boiling water into drain until it opens and starts to drain. Be sure to put towels on top shelves in refrigerator to catch water, then dry completely.
Feb 08, 2010 | KitchenAid Refrigerators
I have a whirlpool refrigerator where water pools under the veggie crispers. It looks like it is coming from the freezer. The unit does not have an ice maker and I suspect a drain line is clogged. Any...
Freezer on top? If so remove rear panel from freezer inside and check drain under evaporator. If clogged, use hot water and turkey baster to squirt water and thaw out drain. DO NOT use sharp instrument to pry ice out. You can use a blow dryer to help thaw as well. Turkey baster helps to jet hot water in drian.
Jun 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Whirlpool refrigerator leaking from top of unit
Listened to other posts and figured drain plug was clogged. It was with ice. Removed bottom pan and back panel of freezer, removed ice on bottom, put hot water in drain to thaw ice until it flowed into pan underneath fridge. Thanks for the ideas.
Jun 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice under freezer floor, water in fridge (drain clogged)
in the freezer remove the cover plate where the fan is an insert a pipe cleaner into the drainage tube opening.
Apr 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
