Question about D-Link DI 514 Wireless Router (DI-514)
Wireless Router Range Problem
Hi, I've been using the wireless router for about 2 years now without any problems. I normally use my laptop from my bedroom upstairs and the modem/router is in the study downstairs.
I never had a problem connecting to the internet from that distance but just yesterday, the router started acting up. My laptop detects the router occasionally but it will disappear from the network list suddenly. I tried using another laptop to connect from my bedroom but its still the same, so it cant be a problem with my laptop. When I tried connecting close to the wireless router (in the study), there wasnt a problem. That means there still is a wireless signal only not as far as it was before. I tried resetting the router several times but it's still the same.
Any ideas why it's happening? Can it still be saved or is it time for me to get a new router?
  • 556 Answers
Have you tried switching channels in the router I have seen suggestions to use challen 1 or 11 instead of the often defaulted 6. You may have increased traffic from your neighbors and non-it devices like wireless phones.
Posted on Dec 21, 2007
How I reset my router to the old password? And how can I use it without Ethernet cable
Hi
There is a wide range of help from here:-
http://www.skyuser.co.uk/forum/tags/dsl2640s.html
but generally resetting to the old password requires access to the router settings. It is often easier to go back to the original settings by using the reset button.
To use the router without the Ethernet cable, you need to set up the wireless settings within the router and then connect using your computer's wireless connection.
If your computer does not have wireless capability, be it laptop or desktop, then you will not be able to connect to the router without an ethernet cable.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Apr 09, 2015 | Computers & Internet
Cannot connect to Wireless with my Linksys WRT120N Router.
If you have 2 devices not be able to connect to it suddenly, then it is probably the router that changed, as opposed to it being the 2 devices changing at the same time. Sometimes wireless routers just go bad like that.Try a factory reset, and then set the appropriate settings back to where you need them. If that doesn't help, you likely need a new one.
Feb 09, 2012 | Linksys WRT120N Router
I have a Cisco WRT120N wireless router. The wireless internet access goes away when I turn off my laptop. When I turn the laptop back on, no more access. The only way to get it back is to pull the...
Have you tried the laptop on another wireless network? It should release and renew it automatically when you reboot the laptop without having to reset the router. And it sounds like the router itself is glitzed. But i would try using the laptop wireless on another router somewhere and also try connecting some other wireless device to the router to analyze the problem. You could also try setting the laptop's ip to a fixed ip number instead of obtain automatically (it must be in the same range as the router - first three numbers needs to be same as the router's) and see if it's the dhcp that is the problem.
A few years ago there were a lot of glitzy linksys routers ...
Mar 18, 2011 | Linksys WRT120N Router
Network has suddenly dissapeered
This is just a problem with the wireless settings of the router, you can try first to reset the router by pressing the reset button for 20 seconds while power is ON and then after that you should be able to find the default wireless name of the router which is linksys, after you reset the router just need to reconfigure it back...
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
Wireless Connection limited range and intermittent
1. Access the router's setup page then go to wireless tab and change the current wireless channel to a different one.
2. You may also upgrade the firmware of your router.
Nov 08, 2008 | Linksys WRT300N Wireless Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Connection problems
both laptops should work wireless without any problem,
check if you named both laptops de same, like "pedro"
need to make sure each laptop has a dinamic IP address setup,
check antivirus and ... that's it.
Jun 13, 2008 | Linksys Ultra RangePlus Wireless Routr...
My laptop cant find my wireless connection but finds other connections in range.I can only connect using ethernet cable from router.spoke to sky who said I need to contact acer as my laptop is not...
you might be blocked your SSID broadcast in your wireless router make it broadcat enabled then it will find your connection.
Your lap is ok and settings are well, b.coz it gets other signales. So just check your wireless AP settings.
Thanks
Iqbal
Apr 09, 2008 | Computers & Internet
I cannot detect my router
A first logical step would be to take your laptop to another wireless location and see if it will work there (you could also take the your wireless unit there to test it). Likewise invite a friend with a wireless enabled machine to visit you and see if they can see your wireless unit. There are three different types of wireless devices in common use A, B, G you need to know which your machine uses and which the wireless receiver uses and assure there is a match. Some devices support multiple types A&G, B&G and A&B&G as long as one matches between the wireless adapter and wireless router/access point assuming the others were not configured off the test should be valid.
Dec 07, 2007 | ASUS (wl500g) Wireless Router
D-Link DI 514 Wireless Router (DI-514) Logo
147 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
