Question about Saws
Need to know how to attach springs on wel bilt attic stairs
We purchased some used wel bilt attic stairs a few years ago and had them installed. We haven't been able to figure out how to hook the springs on so that they pull the stairs back up into the attic space. Can anyone send a photo, drawing or description of theirs??
  • 57 Answers
Contact me directly and I will take pictures of mine and e mail them to you. chibasset@yahoo.com
Posted on Dec 27, 2009
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
I just noticed tonight that my car is making a creaking sound. It's coming from underneath the car in the rear half and is most noticeable when I'm driving slowly or turning (I don't notice it when I'm...
struts are good for 10 years or 100,000 miles at best. your car went past that long ago. i have had 4 saturns and i used half that age/mileage. you can buy a pair on ebay for less than 80 bucks, but spend another 50 and get "quick struts" which have new springs and mounts already installed as a unit, and they are much easier to change. if you bring your own parts, someone who knows what they are doing can do it for a hundred dollars labor, but you will need an alignment too.
Mar 15, 2011 | 1997 Saturn SL
My current water tank was installed 12 years ago With Bladder. 1 hp motor. 80 gals. Water Pressure is consistantly low. When reset to 40-50 lbs, it drops shortly after back to thirty lbs in the house....
If I understand you, this is a water well. For pressure to drop, water must be going somewhere. If you see no leak in the tank, that is not the problem.
Check all outlets, faucets, toilets, showers, outside faucets, etc. If you see no leaks and the pressure is still dropping, there is a check valve either before the pump or in the well and this could be leaking back. Either way, the pressure should drop to zero unless the pump comes back on.
Gary
Jan 25, 2011 | Wel - Bilt Electric Portable Air...
I need a new belt on rototiller.
To replace your tiller belt you will have to :
Take a few pictures before you get started so you know how everything goes back together.
- 1) Remove the belt guard
- 2 ) Loosen the belt pulley and remove spring, remember how this was attached.
- 3 ) Pull the belt through housing and off of the transmission pulley.
Now grab your new belt and install in reverse order.
Feb 02, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Need attic insulation for ladder area
Buy some styrofoam panels at the hardware store. They're usually 2"x2'X4" and they only cost a few dollars. Also get a small tube of construction adhesive. Stick them to the top side. Styrofoam if one of the best insulators you can but. I have it on the inside, of my metal basement door. In the winter, when the temperature drops to 10 °, my cellarway maintains about 65°.
!/16" thick styrofoam protesct your hand from 170° coffee.
Aug 11, 2009 | Hand Tools
Wel-bilt M/99 water pump - shaft seal - what is this thing?
Look for a local dealer in the pump reapir or electric motor repair section of the yellow pages. They likely have the bearings and the seal based on seeing your old parts.
Jun 09, 2009 | AO Smith Centurion 1081 1.5 Hp Standard...
How to shampoo stairs
HERE is the manual
When rating my solution rate the clarity of the explanation NOT whatever you like Kirby stair shampoo system. I do not believe this is the way to shampoo either but this is not me who designed it. Will get the job done but it is a lot of scrubbing and rubbing.
Good Luck
Rocky
Mar 24, 2009 | Kirby G5 Bagged Upright Vacuum
Saws Logo
205 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
