Question about Electronics - Others
Monster power hdp 1800; had momentary blackout of neighborhood. Everythign is back on. MP though has blue ''clean power'' light only; nothing else, tried rest, nothing, tried unplugging, plugging back in, nothing. Outlett has full power, nothing coming out of MP. How to fix????
SOURCE: Hitachi HD 1080 has blue power light on but no picture
Press the reset button...it's on the bottom to the right (underneath the TV). Same thing happened to me.
Posted on Feb 24, 2008
SOURCE: lamp and power flashing amber
The problem is the lamp driver, it can be repalced by dell for $250 plus parts. The specific problem is a capacitor on the driver board, if you know someone who can work on electronics have them replace the 3300u 10v capacitor on the lamp driver board. Usually the capacitor will be slightly bulged on the top (not flat) indicating it needs replacing. Otherwise look for a electronics repair shop in your area and set them in the right direction. Hope that helps.
Posted on Dec 29, 2009
budmrtn
  • 11361 Answers
SOURCE: screen won't turn on - power button continues to f...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 22, 2010
SOURCE: olevia 242-t11 will not power up
replaced all caps on power supply FSP 271-4F02 module.Some caps were bulging @ top some were not but replaced them anyway.Total cost( 10 Electrolytic Caps) from Brantley Elec. fay NC was about $33.00.Took about an hour to remove and solder back.
Posted on Aug 07, 2010
  • 6 Answers
SOURCE: I have a Dell 1800
The projector can fail to start and the power and temp lights will blink orange. This is a known problem with the Dell 1800MP projectors caused by a failed capacitor in the power supply. You can fix it yourself if you know how to use a soldering iron and have some experience with electronics. There are other posts on the Internet that show or point you to the repair. Search on Dell 1800MP power supply failure. If not willing to attempt the repair, I will repair these projectors for you at a cost of $40 plus actual shipping from me to you. You would pay the shipping cost to me. Considering the effort it takes to repair one of these units, this is a fair price. Dell charges $250 for the repair plus parts. I have repaired numerous of these units with 100% success. My occupation is working as a power supply designer for one of the largest manufacturers of drivers for LED lighting. mooredesigns4u@att.net
Posted on Nov 13, 2010
I want to relocate my Ricoh Aficio MP 3300
disconnect the finisher reset it and then it will be a monster roll
Jan 05, 2014 | Ricoh SR 790 - Finisher - 1000 sheets -...
Monster truck 4X4 wii game black screen
it is the game it may be defected and not responding to the system. exchange the game for the same one. if that doesn't work call nintendo at 1800-255-3700, for help on this problem.
Jan 15, 2013 | Nintendo Wii Console
1. momentary sound, then no sound no picture; 2.
Hi, if the power indicator flashes 4x blue more then likely its a SDR buffer logic board. When you take the back cover off they are the long boards on the left side of the tv. There are 2 boards. If you look closely at the black chips on the boards which there should be 8 on each. If you see a burn mark or a deep scratch mark then the chip is fried. If you take the lower one of and turn the tv on it might come on and if not try the top one. Please rate me and let me know how you do.
Jun 25, 2010 | Hitachi P50H401 50 in. Plasma HDTV
61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I was cleanning the power edge 1800 then when i
Check to make sure cables are firmly seated...sometimes when you're inside a box, you might jiggle a cable loose.
May 02, 2009 | Dell PowerEdge 1800 Server
Power outtage has my dlp hdtv actin weird
unhook everything from the tv and wait for a few minutes, go into the factory mode and do a reset, factory mode code is , mute-182-power
Jun 24, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Hitachi HDP J 52 Projector
These small fans are prone to failure; try to access the blades to see if they are being impeded by accumulated dust and also push gently on the blades, left then right, to see if there is any wobble of the shaft.
The fan probably has a sleeve bearing and these are prone to wear and also to stick.
Mar 16, 2008 | Hitachi PJTX100 Multimedia Projector
Electronics - Others Logo
380 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
