Question about Dell Dimension 2300 PC Desktop
How to map usb ports USB1, 2, etc.
Dell Dimension 2300
how to map usb ports USB1 - 6,
that is to be able to label them,
as printers in particular want to stay on same port
    Problem Solver:
  • 10 Answers
You don't map the Universal Serial Buss. You just hook all the devices to the connection points (ports). The computer find them by device, MAC address, etc., not by port number. You can hook up to 127 devices to a computer, and the computer will talk to all of them regardless the physical point of connection. That's the reason, you can buy USB hubs with 4 or more connection points that plug into an USB port (how do you map that?).
USB1 - 6 is for you to know how many devices are connected to the computer via USB at a certain time.
So if your printer is configured for USB1, what ever port you plug that printer in, will be USB1.
Posted on Oct 10, 2009
I have a Dell Dim 2400 and no connection with HP Deskjet 3070A.
Charles, has this combination worked previously, have you been able to print from your Dell Dimension 2400 to your HP Deskjet 3070A successfully?
If the answer to the above is Yes, then if you believe that the printer is still working correctly and you can test this with a different computer able to print to it, you should consider uninstalling and re-installing the HP software and device drivers for this printer.
If you have not printed to this printer successfully previously, have you tested the printer with a different computer and proven it is still working fine?
If the printer works fine to a different computer then providing you are using the same USB cable to connect to your Dell 2400, the problem needs to be narrowed down further.
Check that you can plus other USB devices into the port on the Dell used for the HP printer - if these work, then your USB port is good - if not, try another port if you have one.
If your USB hardware is good, then again you are left with the need to uninstall and re-install the HP software and device drivers - it may be worth trying to download the latest version of such software if available. HP tend to update their All-in-One software on a regular basis.
Dec 30, 2011 | Dell Dimension 2400 (24006YYVP31) PC...
Can a Dell Dimension 3000 connect to 5.1 surround sound
If your Laptop has a "Latitude C/Port Advanced Port Replicator" Then this Port Replicator connects Dell Latitude notebooks to peripheral devices such as a monitor, printer, keyboard and mouse. To accomplish this, connect your peripheral devices to the Dell port replicator itself, and leave them connected to it. Then connect your notebook to the port replicator to access the devices without having to attach them individually each time you want to use them. You can also set up speakers on the Dell Latitude C/Port port replicator to provide improved quality audio.
Follow following steps:
1) Place your Dell Latitude notebook in your C/Port Advanced Port Replicator and turn on the notebook using the power button.
  • 2) Place the speakers you want to connect to the port replicator on either side of the port replicator according to the Left and Right (L and R) labels on the speakers.
  • 3) Plug the audio line connector from the speakers into the audio line out plug on the port replicator. The audio line out plus is on the right-hand side of the port replicator base next to the infrared port, directly opposite the notebook ejection lever.
  • 4) Plug the power cable from the speakers into a power outlet if needed. Battery-powered speakers will not require this. Turn on the speakers following the manufacturer's instructions.
  • 5) Open your preferred music or audio software (such as Windows Media Player or iTunes) on your Dell Latitude notebook and play an audio file to hear the newly-attached speakers.
  • Dec 01, 2011 | Dell Dimension 3000 PC Desktop
    I lost my plug in setup sheet that came with my computer that shows the correct locations that shows where to plug mouse keyboard and printer on my Dell Dimension e510 desktop
    The Dimension e510 does not have ps2 assigned ports only usb, plug your usb mouse keyboard ect to any usb port you like, I promise it will work fine :)
    Jun 01, 2011 | Computers & Internet
    When uploading pictures from my cameras SD card the computer suggests using a hi-speed USB port. I have tried the other ports and it tells me the same thing. Which port is the High speed? Dell Dimension...
    you have no high speed ports installed on your computer. what you have is USB 1.0. you can however purchase a high speed USB pci card (usb 2.0) and install it in your computer to get faster transfer speeds.
    Jun 11, 2010 | Dell Dimension 3000 PC Desktop
    Dell dimension 5100 - usb ports on motherboard are broken
    Flashing Amber is normally power supply
    http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
    The USB ports are part of the motherboard
    Jun 08, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
    Where is the usb port located on the Dell Dimension E-310 computer?
    4 ports on back, 2 on the front, 1 usb header on the motherboard
    http://support.dell.com/support/edocs/systems/dim3100/en/index.htm#printed_documentation
    May 13, 2010 | Dell Dimension E310 PC Desktop
    My usb ports do not workon my dell dimension c521
    1 rollback your drivers, 2 check device manager , Install origional that worked. Also windows updates for hardware drivers.
    Apr 25, 2010 | Dell Dimension C521 PC Desktop
    My pc told me to un-plug my printer from a standard usb port into a high speed usb port, but where are the ports? It gave me the USB hub & ports in a pop-up which is now gone.
    Dear,
    Have you installed winxp service pack 2. only after service pack 2, xp support usb 2. instllall the latest service pack and try the same
    Oct 16, 2009 | Dell Dimension 3100 PC Desktop
    OnBoard USB ports (both front and back) will not recognize any devices
    When you reloaded the OS did you reload all the drivers? Sometimes if you do not reinstall the Intel driver the USB port will not be recognized. Happened on the last two DELL's I reloaded. Go to DELL's website and download all the drivers for your model.
    Dell support website http://support.dell.com/support/downloads/
    Look up your model by service tag, it is the alphanumeric code on the barcode label on the back of your DELL and also sometimes found on either the front or top of your DELL (sometimes it is hidden beneath the USB port cover that you flip up.
    Try that and see if it fixes it. Also make sure that the connector did not come loose when you opened the case.
    Apr 30, 2009 | Dell Precision 360 Workstation/Personal...
    No high speed usb port
    Hi Delvin!
    The 2 usb-ports on the front and the 3 back of your Dell is high speed ones, at least the manual says so, they are all USB 2.0.
    If you cant get them work properly with the 2.0 usb speed, you can buy an high speed pci add-in- card and install it on your pc.
    Here you can read about the "high speed usb" :
    http://www.usb.org/developers/usb20/
    And here is the manual and avalible drivers for your Dell:
    http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
    Good luck to you M8!
    Please take a moment and rate my help for you
    Nic
    Feb 23, 2009 | Dell Dimension 1100 PC Desktop
    Dell Dimension 2300 PC Desktop Logo
    345 people viewed this question
    Alun Cox
