Question about Cameras
Camera not charging red light on charger is on and
Camera not charging , red light on charger is on, but stays on and camera switches on then immediately switches off again.
SOURCE: Battery will not charge
Yep. Same hear. Casio will replace with reciept - call 1300 728 606. Pitty I've lost mine!
Posted on Jan 02, 2008
walkietalkie
  • 32 Answers
SOURCE: battery wont charge flashing red
Every rechargeable battery deteriorates thoughout it's life of usage. may be it's time to buy a new one. Sometimes the terminals on the battery get in touch with metal things and short the circuits within.
Posted on Jul 12, 2008
SOURCE: NV3 Camera - won't turn on or charge
Had the same problem and the following steps seemed to fix it:
Removed battery.
Connected charger lead (but using laptop, not charger - not sure if it matters).
Cleaned battery terminals.
Placed battery back inside the camera.
Posted on Aug 04, 2008
SOURCE: samsung nv3 camera not charging
take out the batter and clean the copper terminals with a sharp knife, plug into the charger if still not working leave for 30 seconds and re-try, it took me four attempts.
Posted on Jul 02, 2009
  • 7 Answers
SOURCE: My Casio Exilim EX-S880 wont turn on. Battery is
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
What does it mean when bcs1 battery charger light is red
sounds like the batteries that you are trying to charge are caput, if it stays red they are not charging if it flashes red its charging if its green they are charged, some chargers work different so check your instructions.
Aug 11, 2014 | Olympus BLS1 Battery + Charger...
Normally when i charge my cameras battery a red light will turn on to let me know its charging and will stay on until it is fully charged but whn i went to charge my battery yesterday the red light began...
Charge your battery with an external power supply or a car battery charger for like 10 seconds (1 ampere will do the trick) by connecting the + and the - of the battery to the + and - of the power supply.
Now insert the battery in your normal charger. ìf it will still not charge do it again for 10 seconds.
Dec 27, 2009 | Casio Exilim EXZ75 Digital Camera
Is the red light on the charger suppose to stay on or blinking for the battery to charge?
It is supposed to stay on. If it is blinking then your battery has gone completely dead. You can force the charger to charge the battery by applying a voltage (AA battery w/ wires worked for me) across the charging terminals while inserting the battery. You'll have to take the charger apart for this.
May 17, 2009 | Vtech Cameras
Battery charger flashing red light
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Nov 03, 2008 | Olympus Stylus 710 Digital Camera
Kenko
read the owners hand book
normally the lights stay red until the battery is charged then it goes green
if the power is cut or if you switch the point off with the charger still in it and do not remove the charged battery , the battery will discharge through the charger
Mar 27, 2017 | Kenko MC-4 DG for Nikon AF 2x (MC4AFNDG)...
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
have been having the same problem. Just pulled the lead out straight and stretched it and now it is charging red light on constantly. May have been a kink in the lead?
Jun 24, 2008 | Samsung NV3 Digital Camera
Cameras Logo
57 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
