Question about GE DBXR463EBWW Electric Dryer
My dryer runs and gets hot but takes 2 or 3 cycles to dry .
  • GE Master
  • 8,404 Answers
Please check your exhaust line fron the lint filter to the outside vent. When I say check, what I mean is take the machine away from the wall remove the hose and vaccum out the drier outlet --- use the crevice tool. When you are done with this, put a nylon over the end of the outlet and turn the drier on. You should have a good amount of air coming out. There will probably be lint - the reason for the nylon is to catch it. If not - do it again. (use the air setting) ... do the same with the hose. If you have access to the other end, disconnect it as well .. check that the door on your outside vent is not stuck shut. If you have a plastic hose, please replace it with a flexible metal hose.
I hope this helps you
a
Posted on Oct 02, 2009
My dryer will not dry my clothes properly. It takes 2 full cycles to dry completely with small loads.
remove the vent tube and run dryer, you should feel hot air, if you do then the vent is restricted. If there is no hot air then the dryer may be built up inside below the lint screen with lint. Here is a website that will explain how to open up the dryer, Hope this helped Tim;
http://www.partselect.com/dryer+open-cabinet+repair.htm
Nov 20, 2010 | Dryers
After a drying cycle the clothes are still wet. We set it on the normal cycle and switch it to Extra dry so it is running for about 59 minutes. After the dryer stops the clothes are still very wet. It...
sounds like an air flow problem meaning the dryer is not exhausting the hot air. Best way to check is to disconnect exhaust tubing from dryer and run a cycle. If the clothes dry normally the vent to the outside is plugged. Hope this helps
Mar 17, 2010 | LG Dryers
My Magic Chef dryer doesn't dry properly
remove the vent from the back of the machine, run it full of clothes from the washing machine and if it dries nicely, then you have a clogged vent that needs replacing.
Jun 16, 2009 | Magic Chef CYE2000 Electric Commercial...
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Loads have to run through high heat cycle twice to get completely dry. It was drying completely with one run through any cycle.
have you checked your wall vent hole and dryer vent hole to make sure they are clear?if there not it will keep the hot wet air from coming out and take forever to dry,let me know-mike
Apr 14, 2009 | Whirlpool LER4634J Electric Dryer
LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Jan 04, 2009 | LG DLE5977 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Maytag LDE412 Dryer
the vent that takes the air from the dryer out of the house is clogged. not the part right behind the dryer but from where it goes into the wall to where it leaves the house needs to be cleaned. when the air cant leave the dryer at normal speed it takes for ever to dry a load of clothes
Nov 26, 2007 | Maytag MDG7600AW Gas Dryer
GE DBXR463EBWW Electric Dryer Logo
144 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
