Magnavox LCD TV - No Power
I purchased a Magnavox 32" LCD TV about 7 months ago. The problem with it now seems to be power related. I don't believe a sustained any type of power surge, but I can't confirm that 100% The stand by light on the power button is on, but the unit will not turn on. I did get it to power on briefly for about 30 mins after it seemed it would not turn on again. I just left it unplugged for several hours, and then tried to power it back on and it did. During this last time I had it on, I checked the menu settings to see if there was anything I can do, such as resetting it. Since the last time it was on it will not power back on anymore. I have contacted Magnavox support and they tell me that they will cover parts warranty, but not for labor. I am very disappointed with them to say the least. I decided to remove the back cover and take a look at the main fuse. It seems ok when I checked it on the multimeter but could it still be faulty? On the main power board I could only find one fuse, maybe there is another one. Well it seems it is power related, but it might be a component level issue on the main power board, or even something else. Anything other suggestions would be welcomed.
Here is the model no. 32MF337B
Thanks,
Kevin
  • sl122282 Jun 12, 2008
    I have a 26mf231d/37. The power light stays green, sometimes flashes off (briefly). The power light is immediately on when plugged in. Completely black screen, no sound.
SOURCE: ViewSonic NextVision N4060w 40 in. LCD TV, will not turn on.
While this isnt an exact fix at work, you will at least be able to view your tv. We have one at work that would do nothing when you hit the power on button, just the usual geen led flashing. We pulled the cover off and found the bulging caps, more than likely from brown outs. But we also found that none were holding a charge. So we held the power button on for at least five min, after the led would stay on for about 30 sec and then turn off. We kept hitting the power button and the screen would try to come on. It finally did. After it did come one we can power on and power off aslong as we dont turn it off for more than 10 min. After 10 min of it being off we have hold down power button again and start the whole process again. So the main problem i believe is the caps arent holding a charge, to be able to kick the high voltage circuit on. We did not replace any caps but if we do end up changing parts will post what was changed and cost. Hope this helps
Posted on Jan 08, 2009
  • 1779 Answers
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Posted on Feb 04, 2009
SOURCE: RE: Dell W4201C
i have a Dell W4201C ,the picture Dims or picture blinks when channel changes
Posted on Jul 03, 2009
  • 3 Answers
SOURCE: Magnavox 19mf337b 5 months various problems power off, ghosting, alarm noise
I am currently working on this model set and have discovered the same type of problems. Fix: 4 capacitors in the power supply section on the main board were defective (bulging out). Common problem with counterfeit parts that originate in China. See http://www.badcaps.net for details.
Posted on Jul 12, 2009
  • 458 Answers
SOURCE: ba71f0f01042 power board blows fuse
I'm not too familar with this model, but to give you some pointers, you will find when you have this problem the fuse will go straight away as there will be some of the semi-conductors short circuited. Check your bridge rectifier diodes & also the chopper transistor in the power supply. As a general check, test most of the diodes & power transistors & replace any that read short circuit on your meter. Hope this may help you as a guide line.
Posted on Aug 01, 2009
32me402v Magnzvox
If the set is still under warranty period, use it. The main power supply regulator board had the fault.
Jun 28, 2013 | Magnavox NEW 32ME402V BLK 32" LED TV 1080P...
I HAVE A 32" VIZIO LCD I PURCHASED 2 YEARS AGO.
You should buy a sodering kit and remove the buldging capacitors yourself. Find a local electronics store, I used Radioshack, and see if they can match the capacitors. I had this happen with my Samsung lcd about a year ago and just help another friend with the same issue yesterday. The sodering is not as hard as you'd think. The capacitors should be under $5 v. paying a few hundred for the power board.
Mar 21, 2011 | Vizio VOJ320F1A 32 in. LCD TV
My visio tv stoped turning on lately.
Hello threefreecol, This is a common problem related to the capacitors on the power supply board. What you can do is to take the back off of the TV and look to see if any of the capacitors on the power supply board are bloated or puffy (signs of damaged capacitors). If they are change them out with new ones (you are going to need a soldering iron and a desoldering pump to do this). In any event this is a power supply problem. I believe your TV is still under warrenty, so you may want to take it to a shop the honors the VIZIO warrenty program. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 12, 2009 | Vizio L32 32 in. LCD HDTV
Magnavox 37mf321D HDTV won't turn on
It may be touching in the back of the tv on a power point. Yours is doing the same thing mine did before it finely all most burnt up it self and my house The metal casting that the tv mounts on in the tv ,does not have enough room in it. the metal casing touches one of the power supplys in the back and shorts out. If its like my 32'' magnavox flat panel
Apr 14, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Oct 28, 2008 | Televison & Video
Protron TV 32
If your TV is not turning ON, the power supply is defective. It's a bit hard to find service parts for these TVs, the only way to fix the power supply is to replace the defective parts.
If you need more info let me know or you can write to jah2mil@hotmail.com
Jun 17, 2008 | Protron PLTV-32 Television
Wharfedale TV power problems
got a 32 inch wharfedale tv from argos also and it seems to boot up and then shut down and just loops, if i keep unplugging it i can sometimes get it on but with a high pitch wailing, only 15 months old, gutted!
Jun 16, 2008 | Televison & Video
Insignia 32 inch LCD TV: Can not change Channel or Volume !
I have one in my shop with the same problem. Power is the only function that works. I repaired the power supply six monts ago. Now it looks like a bad digital processor board which is non-repairable. I can't believe what's happened to the tv business. Absolutely disgusting!
Oct 12, 2007 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
642 people viewed this question
Top Televison & Video Experts
