Question about OKI C7200 Printer
How do i Remove a paper jam from my OKI C7200 ?
  • 624 Answers
SOURCE: OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
You probably have already looked this up by just in case here is Okidatas instructions for clearing this jam: http://my.okidata.com/PP-C5100n.nsf?opendatabase. If you have already looked here and done this then I would suggest: -Open and close the rear cover. -Pull out and replace each of the toner cartridges. -Pull out the duplexer, ensure it is clear of jams and replace. -Pull out each of the paper trays (including the manual tray), ensure paper is installed correctly and replace. -Close the top cover. Per Okidata this has to be done last or else you will continue to see a jam error. -Try unplugging the printer and letting it set for a few minutes and retry. If that fails you might try purchasing a can of air from the computer store (about $3) and blow out the paper path to clear any paper or dust that may be blocking an optical sensor.
Posted on Dec 03, 2006
flopez
  • 161 Answers
SOURCE: Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Posted on Sep 22, 2007
  • 260 Answers
SOURCE: oki 5250 380 paper jam
Sometimes you will find debris has fallen into the printer. Take off back to clean it out. Something as small as a staple can create this problem.
Posted on Apr 09, 2009
  • 44 Answers
SOURCE: oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Posted on Apr 18, 2009
  • 21 Answers
SOURCE: oki b6200 paper jam
restart the printer or reinstall driver again.
Posted on Oct 08, 2009
How to clear a fake paper jam in oki B6250 printer
The usual cause of "fake" paper jams is a prior "real" paper jam. One of two things occurs.
  1. A small bit of paper tears off the jammed stock and hides from view, but keeps the printer jammed. These can be hard to find and remove, depending upon where they are.
  2. In the process of yanking the jammed paper out of the unit, the sensor(s) become damaged or misaligned and give false jam indications. This usually needs repair or replacement.
Jul 30, 2015 | OKI Office Equipment & Supplies
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at http://www.okidata.com/ .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
Oki C5500 printer keeps jamming
Open the tray and find yout imput roller. You can remove this roller and put it back on the other side. Normally this is caused because it is worn. The inside of the roller is like a new one.
Jan 11, 2010 | OKI C5500n Printer
Oki B4540 keeps saying
You should certainly start by looking at the toner cartridge to see if there is any tape to remove. If there is no tape with a visible pull tab, check inside the printer to make sure that there are no pieces of torn paper stuck anywhere inside.
May 05, 2009 | OKI B4350 Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Oki b6200 paper jam
Have you checked to see if there is any paper jammed in the sensor, at the back in the 150-sheet feeder assembly, if not the paper could be stuck the 150-sheet assembly
Feb 26, 2009 | OKI B6200 Laser Printer
What's different of oki c7200 and c7300 cartridge?
They are different and can not be interchanged
C7200 work with C7200/C7400
C7300 work with C7350/C7300/C7550/C7500
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 14, 2008 | OKI Office Equipment & Supplies
Oki c3400 paper jam
Run Status Monitor and make sure it is really a paper jum that prevents printer from printing. It is very likely that another reason is in place. For instance - toner empty of change drum request. All of this causes the "Attention" LED to blink: it's not only paper jam that causes it.
Oct 07, 2008 | OKI C3400n Laser Printer
Aug 22, 2007 | OKI B4300 Led Printer
OKI C7200 Printer Logo
46 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
