Question about Toshiba Satellite A135-S4527 Notebook
My laptop toshipa A135 has died. when i push power
My laptop toshiba A135 has died last night. when i push power switch, i see led indicator is turning on but no display can i see in the LCD.
i try with external monitor but that same no display.
when i eject dvdrom thats no respond and dvdrom led still off.
baterry charger still work at all.
help me please.....
  • 154 Answers
In this case you need to check the inverter, defective inverter will cause the following symptoms:
No Display
dim screen
Screen Flash on and Off between 1/2 to a few seconds
Actually you need to replace the inverter buy a new inverter which is compatible to the old one. Installing the inverter is easy, it does not require any technical skills. In fact, it is a lot easier then changing the I/O Card in your PC System because there is no driver ( Software) Involve.
Tools:
Philips screw driver
Small Flat screwdriver
Preparation:
Make sure your have enough space on your desk and it must be clean.
Disconnect AC Adapter and Remove Battery from Laptop Computer.
Procedures:
This procedure is based on Toshiba Satellite A105-S4284 (with 15.4 inch Screen)
Removing the front bezel on Laptop screens is easy. Usually, these screws are covered by small rubber pad; so, all you need to do is remove these rubber pad and screws. To do this procedure you can find some instructions as shown on the next few photos to the link that i can provide below.
http://www.lcdparts.net/howto/instruction/IInverterDetail.aspx?Model=A105-S4284
Good luck, thanks for using fixya
Regards
nicole
Posted on Oct 03, 2009
I HAVE A TOSHIBA SATALITE A135-S4427 TURNED IT OFF ONE NIGHT WORKING FINE, THE NEXT DAY IT WONT TURN ON. I HAVE POWER THRU THE CORD AT ABOUT 18+ VOLTS BUT NO INDICATOR LIGHTS OR POWER TO COMPUTER. HELP?
Try removing the battery and power supply, hold the power button for about 10 seconds then just plug the power supply back in (not the battery) and see if it turns on.
Holding the power button with no power supply can discharge any stored power in capacitors.
Oct 24, 2013 | Toshiba Satellite A135-S4427 Notebook
What do the various led light colors mean? I have
The LEDs each indicate something is conected or normal. There is one for hard drive activity, power, battery, and wireless. Blue is good. Orange is bad. First take the charger to a shop to have it checked. If bad replace it. If good the the problem is either battery or the connector on laptop. Since the battery is new it sounds like the connector to me.
May 01, 2010 | Toshiba Satellite A135-S4527 Notebook
Froze up last night, turned off, will not turn on now
Try removing the laptop from A/C power, remove the battery, then hold the on/off switch in the ON position for ten seconds. Replace the battery, plug in to A/C and try booting. Laptop may be frozen in 'sleep' state; I have seen this problem with other Toshiba's before.
Feb 11, 2010 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellie A135-S4467 is not turning on
If they tested the PSU,power and found it to be working, and they
put your memory into another laptop and it worked
I would say it is your processor, most times people forget these cool from the bottom and they set them on places that they can't keep themselves cool and overheat.
If it was be, I would buy a used processor on ebay that was guaranteed to work, before buy a mobo,
Buy check the pice of both and see if its just better to buy new, with the advancement of processors, prices have dropped.
Feb 09, 2010 | Toshiba Satellite A135-S4467 Notebook
Toshiba A135-S4527 will not boot
Could be power supply (ac block and power cord) is dying or died. Laptops are notorious for this.
Aug 01, 2009 | Computers & Internet
Monitor no power
manipulate each ac power cord wiggle it . PS died?
Aug 01, 2009 | LG 19" Widescreen Flat Panel LCD Monitor
Problem with toshiba A135-S4527 ,MOTHERBOARD NOT INITIALIZING
Try this:
I left mine on, in its coma cond overnight. The next am I touched the enter key and it booted up! 5 days later it went back into is coma.
Yeah, Toshiba Laptops ****! My A135 S2246 is doing the same thing. You and I aren't alone either. Search for: "toshiba sucks" and you'll see how many there are, lots of them. 1 week after warranty expires it started doing exactly what yours is doing. I swapped out ram with known good ones, HDD also, I connected external monitor, keyboard, nothing changed. I re-seated the CPU, temp disconn cmos batt -no help.
Cleaned all the connectors & grounds, no help.
Observations:
Fan runs on & off, I feel heat being pushed out.
Can hear Hdd spinning, indicator led briefly flashes when I first turn on.
Fn indicator led will illuminate, sometimes.
caps lock led -not at all.
numeric keypad led, no.
the only key that seems to do anything is Fn.
Toshiba wanted $35. just to discuss it over the phone. -WRONG!
Its now two years old and about as useful as a milk bucket under a bull!
Jan 13, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S2276... went in sleep mode.
Try pressing power button once. Does Windows logon screen come up?
Jan 13, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
264 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
