Question about Sanyo Televison & Video
How to tune a sanyo ce27lc6-b in - Sanyo Televison & Video
2 Suggested Answers
jaseel1
  • 556 Answers
SOURCE: What sort of lead should
So here's a quick walk-through of all the methods that I know (if you know any more, please comment) to connect a laptop or PC to your TV:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here's a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel free to comment!!! Thanks!
Posted on Nov 13, 2010
When is witch on,no picture,top left of screen says in red OFF 10
The witch will be on at the end of the month (Halloween) Check your front door often and have candy ready or you will be cursed.
Oct 16, 2014 | Sanyo Televison & Video
Sanyo ce27lc6 b
What is the problem you faces with this TV? Provide more details please. If you wish to get more details, check the site linked here http://electronicshelponline.blogspot.com/
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 10, 2013 | Televison & Video
We just bought a Sanyo LED tv and channel ten is not found when auto tune is done someone please help!! :)
Test the signal strength using analogue tv mode and teletext page 284. If this shows no issue open up the TV tuning menu and use 'Manual Tume' until the missing channel shows on the screen and then Save.
Apr 03, 2012 | Sanyo Televison & Video
I need tv tuning codes for sanyo c25eg95b
Read the Instruction Manual for the Universal Remote Control it should have an Auto Tune feature where you can set the code by pointing the control at the TV when on and pressing the POWER ON and SET button on the control together for 3 seconds, when the TV turns off press the TV button immediately, Good Luck
May 17, 2010 | Sanyo Televison & Video
I have an old sanyo TV with only one av how can i tune VCR into a
You don't need too! All you need to do is get one of these boxes and you can connect all to that one scart, plus record the freeview to your vcr. They are not expensive, I got mine from Amazon.
Apr 04, 2010 | Sanyo VHR-H531 VCR
My sanyo tv will not cume back on the fan went in the back and i didnt no would i be able to fix it? its plasma.. modal number ce27lc6-b can any1 help please!
Email me and I can help walk you through the procees of getting the fan out of the tv. If the fan is still inside the tv be sure to keep the tv unplugged... The fan has metal casing and could short out the circuits inside the tv. Potential electrical danger if you leave it plugged in the ac outlet with a fan dangling inside the tv.........
circuitworld@comcast.net
http://www.corkin.com/Profile/view.cfm?userid=77703
http://www.google.com/profiles/circuittvrepairs
http://circuitworldrepair.com/cwr.html
-Contact Us 443-802-7251
Oct 29, 2009 | Sanyo Televison & Video
LCD-32 TV.Can not tune in channel 7
81CM HD Sanyo LCD: Was still under warranty, took it recommended repair man and he simply tuned it at his shop!. Perfect when I connected it at home...Bob Tape
Jul 29, 2009 | Sanyo Televison & Video
Memory pictur
i haveing dan it and i want to known that the sanyo tv if the fauth is fane tuning where is the fauth thank you
Aug 22, 2008 | Sanyo DS20930 20" TV
Tuning Sanyo VCR
Press both channel buttons simultaineously for 3 seconds it will automatically tune your programmes press ok when ok flashes on vcr screen display
Nov 04, 2007 | Sanyo DS27910 27" TV
Televison & Video Logo
100 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
