Question about LG WM2688HWM TROMM SteamWasher
Horrid smell in clothes - LG tromm front loader
I just stumbled onto this thread - my problem is the same as others. Just got off the phone with LG - told to do all the things I've already done - it's "my" problem, I must be doing something wrong. I've even tried the "Smelly Washer" product - no luck. The applicance man at Sears yesterday saw me looking at washing machines and TOLD me not to even look at the front loaders - they all had the same problem. Meanwhile, I'm stuck with a thousand dollar machine that has ruined all my clothes. I keep a new set of towels just for company. Once you get that smell in your nose, you just can't get rid of it. Has anyone come up with anything different to try> I'm heartsick and can't afford to buy a new machine. Mine is only 2 years old.
    President:
  • 1,865 Answers
Odors are caused by a variety of particulates, and each is neutralized by a specific formula.
I don't know what type of odor you are dealing with, so we'll start with first attacking any soap residues. Buy a gallon of white vinegar, and run a small laod wash cycle using hot water and add 1 quart of vinegar and 1 cup of baking soda, repeat a second time.
After the vinegar treatment, run another small load wash with hot water and 2 cups of bleach, and one cup of baking
Finally, dampen a rag with vanilla extract, and wipe down the the inside of the tub and door.
Write me at buffalonymann@yahoo.com with your results
Posted on Oct 02, 2009
Water not filling machine and do not see suds but it does sound like its filling up. Hear it filling but do not see any water
Not sure of your model but the larger LG front loaders have 2 pumps, 1 for drain and other to pump water up over the clothes through a fitting in the top of the door rubber seal. If something is stuck in the pump or the pump has failed the clothes wont get wet.
Apr 19, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Do not buy an LG Tromm front loader unless you want stinky, moldy clothes! The first few months, I LOVED this washer, but now I think the machine is possessed by smell demons! I've tried everything, but...
Stinky clothes are usually the result of washing in cold water. Cold water will NOT kill bacteria.
Add one cup of vinegar to the wash before you start the machine - try it.
The vinegar will kill the bacteria during the wash. Your wash will NOT smell of vinegar.
The dryer level of dryness on most auto dryers needs to be set three clicks toward + on most machines. LG is no different.
Apr 02, 2010 | LG WM1812C Front Load Washer
LG leaking from bottom, Not the filter clean-out.
Not necessary to blame LG, ALL of these front loaders are garbage. They were designed poorly and released too soon just to have a new gimmick.
Jan 16, 2010 | LG WM2688HWM TROMM SteamWasher
My clothes smell mildewy. Why?
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
Clothes stink after washed in lg front loading machine
You may have already found a solution, but I had this exact same problem. I ran the tub clean cycle with bleach and then switched to a powder HE detergent. I found some other posts that said that liquid HE detergent has some thing in it that causes that smell and the tub build up (not sure what?). I was hesitant that that could really make a difference but it has. It has only been a week, but so far everything smells great. Definitely worth a try.
Jul 20, 2009 | LG WM-2277HW Front Load Washer
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer smells bad
Whirlpool and Tide make a cleaner that you put into the washer and run it through a cycle. Front loaders get a build-up that cannot be cleaned by hand. Make sure you are using a detergent that is marked "HE". Do not overfill the detergent or softener cups. I've heard that other used a lot of bleach in a wash cycle to clear out the smell. Bleach is bad to use if you're on a septic system, though.
May 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
LG Tromm Washer
Wash empry with detergent and double bleach with extra hot water. When cycle is complete open the door to the washer and let airdry. When you close the door with it wet it becomes a breeding ground for bacteria. You may also not be using the correct detergent or the correct amount of detergent.
Jan 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM - awful smell while washer is running
Use the aafesh tablets as instructed, this will clear hoses that have developed some mold, also inspect drain at the wall, these get moldy and as machine runs, smell comes out of there as well.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer a Tromm LG DLE377W leaves a bad smell in clothes after washed the smell is in the washer also smells sour
Sears has tablets for front load washers that work great. I use one every month and it has helped the stinky washer smell and the bad smell in the clean clothes. It is called Affresh and it works better than any of the cleaners you can buy in the grocery stores.
Aug 07, 2008 | LG Washing Machines
Washing Machines Logo
198 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
