Question about Proscan PS60690 60" Rear Projection Television
TV turns on and off by itself. Volume can't be controlled with remote control and if you push volume control on the TV itself it turns the TV off and on.
  • 647 Answers
The font key switch panel is defective - (usually one of the switches has changed resistance) you can unplug the keypad and just use the remote. You can access the kepad thriough the back panel - but to remove the keypad you have to remove the chassis. Let me know if this helped.
Posted on Oct 02, 2009
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Jan 19, 2010 | Universal Remote Control DIRECTV Universal...
My sky remote control has recently stopped turning my tv on and off and also controlling the volume. I have encountered this problem before but after a day the problem has righted itself. My tv is a JVC....
Hello Rina
Please follow the steps below with the sky remote:
TV
RED + SELECT
TV
0053
press the volume button if this works press the SELECT button to save if not press TV then volume again. repeat this step until the volume works. Dont forget to press the SELECT button to save the code.
Hope this Helps
Cheers
Little Dish Fitter
Sep 18, 2009 | Televison & Video
The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
May 10, 2009 | Sansui HDLCD3210 32 in. LCD TV
Volume controls do not work on remote, batteries have been chang
is that from remote no volume try tv volume if ok
your remote volume buttons are wornout push
button harder ??ok no i can fix remotes
need help call 0403960527
Feb 16, 2009 | Samsung TV Remote Control
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
Controls
Someone push the volume up button too hard and is stuck,this also has the micro(brain) confused,all this happen before you fund out your remote would not work.
Sep 03, 2006 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Open Questions:
Proscan PS60690 1st turns off then on by itself. Then 3 on-off cy I've had this exact problem twice. The 1st time I replaced the RCA part number 205064, which I believe is called the HV splitter. I used a generic non RCA part. The TV worked great for several months but went out again and it has been broken for 2 years. I finally ordered the new true RCA part number 205064 HV splitter. The TV, again seemed to be fixed, and what I a beautiful picture it had through our cable box. But, no happy ending at this point. It worked for a couple of days and then turned off and back on while my wife was watching it a few minutyes ago. It cycled off then back on twice in a 3 minute period so with the picture showing and tv still on she went ahead and turned it off. This is how the problem began several years ago the 1st time it went out. I don't want to turn it back on anymore in case the brand new HV Splitter is still OK. Does anyone know what other parts may be going out, causing the HV splitters to go bad and start shorting out. I know the HV spitters have been an ongoing problem with these sets, but since I just put a brand new RCA one in only 2 days ago I'm wondering if something else goes out first and causes the splitter to go bad after a period of time. I would appreciate any help. I can't afford a new set right now and the picture looks so great on this set using a cable box I feel it's definately worth fixing. ps Could missing o-rings cause this? I've never seen the o-rings. Even the first time I replaced the HV Splitter. Thanks
Feb 28, 2017 | Proscan PS60690 60" Rear Projection...
Televison & Video Logo
169 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
