Clarion DB245 CD Player Logo
Posted on Dec 21, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clarion DB245 Hooked up Red to +12VDC, Neg. to chassis ground..and no response, no display. Some current drav upon connection to chassis. Occasional CD drive noise.  Unit barely used, and transfered from one vehicle to another.  Puzzled. Is there a reboot or security code? Thanks.
Anonymous
Level 2:
  • Expert 111 Answers
  • Posted on Dec 21, 2007
Anonymous
Expert
Level 2:
Answers
111
Questions
0
Helped
55020
Points
217
You need to connect the YELLOW wire to +12VDC also.
The YELLOW wire is for the memory of the radio and it connected to constant power line.
My Clarion NX706 would somehow power On but the display just gets stuck with the screen showing the name Clarion. It would not complete the boot process. How can I fix this?
Press the RESET button when the Clarion NX706 is turned OFF;Use a Multi-meter and test the yellow and red wire. Make sure always available +12VDC is measured on the yellow wire; meaning +12VDC is measured even when car is off. Test switched +12VDC on the red wire; meaning +12VDC is measure only when the key is turned to acc.
As part of the testing process:
test for +12VDC on the blue/white wire when attempting to turn on the Clarion; test for +12VDC on the blue wire as well.
8helpful
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
2helpful
I need a wiring iagram for a 1980 clarion radio & CB for a honda goldwing can you help
clarion radio!!!!!!!!!!!!!!!!!!!!!
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
with the cb just connect the red and black wires upto the red and black on the radio then the cb wont switch on until u turn the accessories on
pls rate people arnt rating hope this helps
13helpful
After wiring diagram for Clarion DB156
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
Connect color-coded wires properly;especially the
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
3helpful
Need to know how to set the correct time on the clock. Clarion DB245 cd/radio
I have to search for this every time too. This product has an incredibly non-intuitive button inetrface. From the instruction manual (which can be found at http://www.devicemanuals.com/guide/Car%20Audio/Clarion/Clarion-DB245-CD-Installation-Manual-TkRZeU5qVT.html):
4helpful
Wire color code on a db245 clarion radio
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
Clarion db245 NEED WIRING HARNESS FOR CD PLAYER
it can be ordered from www.pacparts.com
Part number 854365900 for $15.89
CD Won't Come out of CD Player - DB245
THE MOTOR RESPONSIBLE FOR EJECTING THE CD MAY HAVE FAILED U CAN OPEN THE TOP OF THE UNIT AND TRY TO RELEASE THE CD, BUT BE CAREFUL THEY R DELICATE PARTS
2answers
Clarion DB245 CD player
I think you press and hold the band button then press the display button
Top Clarion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
