Question about Whirlpool Dryers
My LGQ9508PV dryer operates (drum spins) but there is no heat generated. The flame does not come on at all. Can anyone tell me the most common cause before I purchase a lot of parts and work by trial and error?
    Scholar:
  • 35 Answers
Check the wires at the Element. Wire sometimes blows off of one side of the Element.
Chech with an ohm meter to see if the Element has opened
See if there is 240Vac at the terminal leads at the Element, If not, there is a round thermal cut off that one of the Element wire goes to first, then to the Element.
These are the most common thing's that I have found in these machines.
Best!
Robert Wagner
Posted on Oct 02, 2009
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
No heat from dryer
If a Gas dryer look first to see if igniter is coming on or if drum where clothes are gets hot or not.
Dec 10, 2012 | Dryers
Heat shuts off after a few minutes
Clothes Dryer Repair and Common Problems - Loud Noises, Overheating and Not Spinning84rate or flag this page
By expectus
1342481_f260.jpgBasic inside of a dryer, picture from hometips.comClothes Dryers Problems
I decided to start this hub due to the amount of problems I have been having with my current clothes dryer , and what I went through to fix a few problems I had with my dryer including a broken tumbler belt and loose tumbler drum.
So the basic design of a dryer hasn't really changed much and most people will find that there dryer will last a long time and wont generally need a complete upgrade and a few fixes every now and then will keep it running for a very long time.
So depending on the design of your dryer it will look pretty much similar to the picture on the left and contain all the main components. The main parts that usually require fixes or maintenance include
- Drum belt and Rollers
- Motor and motor bearings
- Blower , heater and heat sensors
1342506_f260.jpgSafety and Cleaning
The first thing is to make sure everything is unplugged before starting to tinker inside your dryer, and depending on the style of your dryer pull the back door or hatch off slowly so you dont accidentally rip off the wires.
Some old dryers also have very loose tumbler drums so when opening the back door hold the drum in place to stop it from banging around inside the dryer compartment.
Cleaning
Cleaning is very important for your dryer, and after opening up my clothes dryer after about 10 years of use I could tell it really needed some regular maintenance and cleaning.
There was an amazing layer of dust covering everything and the actual box compartment was dull of dust and little bits of sand and dust. For newer dryers this may be less of a problem but sometimes if you hear your drum spinning a bit loudly it may just be a large layer of dust and dirt.
Common Problems
1. The Clothes Dryer Drum is not spinning or not spinning correctly ( loud noises and screeching sounds)
- The most common reason for the dryer drum to stop spinning is if your drum belt has snapped or has been worn down completely. This is an easy fix and simply involves buying a replacement belt and feeding it through the pulleys and on the roller and then back around the middle of the drum.
- The rollers could have worm out causing the drum to spin in a bumpy and noisy manner , these are the little circle shaped objects your dryer actually sites and can usually be replaced depending on how old your dryer is. The pulleys could also be broken causing problems.
- The motor could have died after many years of use if the drum is not moving at all and if it is moving the motor bearing could be off causing to spin around very roughly and sometimes scratch against the sides of the dryer compartment.
- Noises coming from the dryer when its plugged in and spinning could also be due to a huge amount of dust built up around the dryer drum. Sometimes cleaning out the inside of your dryer and returning the drum to the correct position can fix this problem.
Screeching noises are not a good sign and sometimes its a sign that you drum is slowly cutting into the sides of your dryer which could permanently put your dryer out of use if its continues.
1342561_f260.jpgDigital multimeter, look for resistance settings or OHMS symbolClothes Dryer Heat Problems
Another common problem is that your dryer will either run too hot or too cold , and sometimes take many cycles to simply dry a few items.A useful device that could in handy for testing that each component is working is a simple multimeter or volt meter you can buy from an electronics store.
The way you test the functionality of each component is to get your multimeter or voltmeter and put on the lowest Resistance setting,
Temperature Switch - Leads on switch terminal should read zero or infinity
same for thermostat, heating coils and timer testing.
The most causes of these sorts of issues are
- The temperature sensors could be dead or fried and need replacing, they look like little silver dollars and are usually located under the drum.
- The exhaust outlet could be clogged with dust and dirt causing your dryer to run hotter than the temperature you set it at.
- thermostat or heating coils could be defective and need replacement
- There could also be problems with the timer, if the timer is not working correctly this may cause the heater and blower to remain inactive.
- The fuse is dead and needs to be replaced.
Dead Dryer Alternatives417uoqjhrbl._sl75_.jpgPolder Two-Tier Free Standing Clothes Drying Rack with Mesh Garment DryerAmazon Price: $21.52
List Price: $29.99410qipqvuwl._sl75_.jpgIndoor Clothes Drier Y Airer Rack, 79'Amazon Price: $33.00
List Price: $51.9931c6s6bhkol._sl75_.jpgSteel TAssembly 4 pcAmazon Price: $24.95
List Price: $33.99Dryer totally Dead wont Start
So your dryer wont start at all this can be caused by the failure of one or more components and is sometimes hard to pin point.
The most common are below apart from problems relating to your power mains
  • Timer or thermostat
  • Terminal block
  • Start switch
If anyone has any problems with there old simpson dryer I may be able to help you out as I spent a lot of time tinkering with my old simpsons clothes dryers.
Jan 11, 2012 | Dryers
Hi, My dryer has stopped dying the my cloths is this a common problem?
No, is the dryer drum spinning? If not, replace the drum belt. If the drum is spinning but not drying the colths. The dryer heating elements is burnt out and needs to be replaced. GB..stewbison
Aug 31, 2011 | Fisher and Paykel SMARTLOAD DE62TG1...
Gas dryer works, but does not heat
Hello there:
here is a discriptive way of trouble shooting the dryer and it lists the common components that will normally fail if the element has not failed first
Gas Dryer Diagnosticsgasdryerguts.gifThis picture shows the main parts of a gas dryer's burner systemthat can fail. Understanding each component and it's failure mode canreally help diagnose a problem with a gas dryer.
Ignitor failure: The drum turns but the igniter doesn't glow, thereis no clacking sound as the gas valves open and there is no flameignition sound.
Radiant Sensor failure: The drum turns but the igniter doesn't glow,there is no clacking sound as the gas valves open and there is no flameignition sound.
Gas Valve Solenoid failure: The drum turns and the igniter glows andgets turned off but there is no clacking sound as the gas valves openand there is no flame ignition sound.
And another component failure to be aware of, but that's not shown here, is the operating thermostat:
Operating Thermostat failure: The drum turns but the igniter doesn'tglow, the gas valves don't open (there is no clacking sound) and thereis no flame ignition sound.
And here's a picture of other components to ohm out if you're getting no heating at all:
Nov 21, 2009 | Hotpoint Dryers
Dryer does not heat
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Nov 04, 2009 | Video Cameras
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Gas Dryer is no longer generating heat. Air is moving, drum spins
The most common problem I have found with gas dryers is the heat sensor which shuts off the burner when it senses too much heat. Check the sensor with an ohm meter. If your not an electrician I suggest you contact a service person.
Nov 26, 2008 | Kenmore Dryers
Dryers Logo
61 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
