Question about HP DeskJet F4280 All In One Printer InkJet
WHY WONT MY DESKJET 4280 SCAN - HP DeskJet F4280 All In One Printer InkJet
I want to scan a document from my HP F 4280 to my computer so I can work on a project. How do I scan and save?
Use the HP Solution Center Software provided with your HP Printer.
You can also download the software from www.hp.com
The software will give you instructions on how to save the images.
It is all about finding the folders, usually with filename scan0000, scan0001, and so on.
You can modify the naming of scanned docs, pics.
God Bless You!
Feb 05, 2011 | HP DeskJet F4280 All In One Printer InkJet
I need installer for my hp deskjet 4280 i lost my cd.. Tnx a lot!
go to the hp website and download the drivers, its pretty easy.
www.hp.com
look for the support and drivers link in top rh corner of page
enter your model number (deskjet 4280) in the box, select download drivers and hit [enter] or click the little button to the right of the model input field.
Select your operating system.
Choos whether you want the full installer or just base driver (grab the full installer if you have broadband)
once it is downloaded, run the file and follow the steps to install your driver.
Plug in your printer when prompted.
Jul 05, 2010 | HP DeskJet F4280 All In One Printer InkJet
My hp 4280 all in one wont print. it shows an
Rather than to analyze your problem and fixing, just uninstall all the softwares related to your printer from the control panel and reinstall them back using the driver cd came along with your printer and this should fix your problem. If still the problem persists, then try connecting and printing from any other PC/laptop to find out where exactly the problem is.
I hope this is helpful to you.
Thanks
Feb 07, 2010 | HP DeskJet F4280 All In One Printer InkJet
Hp 4280 print cartridge wont go to middle when the door is open
When ever you are inserting the cartridge, than make sure the printer is powered on
Jul 09, 2009 | HP DeskJet F4280 All In One Printer InkJet
Can't scan on my HP Photosmart 4280
hi 1st of all remove ur old driver and then try to install this one from herehttp://www.userdrivers.com/Printer/HP-Deskjet-F4280-All-in-One-Printer/download/
Jun 08, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP Deskjet 4280 does not print. 'E' error on Control panel button
I had the same problem. It was solved once I bought an original color cartridge. Refilled cartridge seems not to work on this printer. Glad if it might help.
Jun 01, 2009 | HP DeskJet F4280 All In One Printer InkJet
Register new product
The 4200 series is just part of the Family.there are other models that begin with the numbers 42 like yours 4280, 4260 -----usually in regards to speed & options ect...
Feb 02, 2009 | Office Equipment & Supplies
Need to download and install drivers for hp deskjet 4280
Click Below Link --> Select Your OS --> Download Drivers --> Simple !!!
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3390948&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=3390945
Jan 20, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP DeskJet F4280 All In One Printer InkJet Logo
37 people viewed this question
Seeker5211
Seeker5211
