Question about Sony Playstation 3 (PS3) Console
Lag between ps2, ps3 and LCD TV.
When my playstation 3 or PS2 is hooked up to a normal television it works fine. However i recently purchased a flat panel LCD TV and have noticed that there is a lag between me pressing a button on the controller and actually seeing that particular button executed on the TV screen. Meaning, if I'm playing a baseball game and I press X to swing, it takes longer than it should for the batter to start his swing. It's not a terribly long at all lag but it is noticeable and does get annoying with timing games such as this.
  • Anonymous Feb 09, 2008
    Just bought Olevia HD LCD 37" and when playing guitar hero III on PS2 there is lag when pushing the buttons. You can not complete game because you lose.
    it works fine if i go back to the old tv. any suggestions? is there firmware for PS2 that needs to be loaded? should I use a different cable
  • Anonymous Oct 21, 2008
    There is a very small but noticable lag which is very irritating, as i just bought an hdtv, why isnt this issue more publicised, there must be a way to rectify the problem is ther a way to change the resolution or something.................help me someone..
Reply for LAG!!!
You know alot of people dont know this but lcd tv's also have a speed and well the speed of your ps3 exceeds the response time the tv has. Which means some lcd's can be 1080p over 10,000:1 contrast ratio BUT can be slow.
Posted on Feb 18, 2008
This is not only the case with the ps2 and ps3 but also with xbox and xbox 360. I dont own a playstation but with the 360, I have tried all the different cables (composite, Component, VGA, and HDMI) and they all produce the same result. The issue is with the LCD TV. I have noticed that some games are worse than others. COD4 is hardley noticable, but halo 3 and GH3 are unplayable it is so bad.
Posted on Jun 11, 2009
  • Kristian91 Jun 11, 2009
    this is not only the case with the ps2 and ps3 but also with xbox and xbox 360. I dont own a playstation but with the 360, I have tried all the different cables (composite, Component, VGA, and HDMI) and they all produce the same result. The issue is with the LCD TV. I have noticed that some games are worse than others. COD4 is hardley noticable, but halo 3 and GH3 are unplayable it is so bad.
    Problem Solver:
  • 8 Answers
2 questions:
Are you using HDMI cable?
Have you tried your ps3 in any other HDTV?
Heres why I ask you this. PS3 has some compatibility issues with some TVs (or Tvs have it with ps3....that is controversial xD) so if you happen to be so unlucky to have bought an HDTV which ps3 has issues with, you`ll have a problem (as was my case)
In my case whenever I switch resolutions or enter a game the HDTV starts flashing between the ps3 screen and some blank screen with dots. I have to remove the hdmi cable and connect it again and it solves. :D
So please answer my 2 questions in order to discard some possibilities.
Posted on Dec 21, 2007
2 Suggested Answers
SOURCE: Time lag between Playstation 3 and LCD TV.
SOURCE: http://boardsus.playstation.com/playstation/board/message?board.id=confrontation&thread.id=735278&view=by_date_ascending&page=2
If your playing with lag on your new HD LCD your at a competitive disadvantage! Everything you see happens seconds later than your opponent who has his/her settings right.
The fix:
1. Connect your PS3 using HDMI Input 2.
2. SELECT or RENAME the HDMI Input to PC. Already pointed out, but this does not make the majority of tv's run in PC mode.
3. On the PS3 start-up menu go to Settings---> Display ---->
Choose HDMI ----> DO NOT choose AUTOMATIC ----> SELECT CUSTOM ----->
4. Now, Select all the Resolution options EXCEPT 720p. This will force your games into 1080p mode. What it will also do is drop any game that doesn't have 1080i/p support into 480. Games like Burnout Paradise, Vegas 2, Heavenly Sword, NHL 08 and more will be dropped into SD (480) rather than HD. Your picture will be terrible. 720p is standard gaming resolution currently, 1080i/p is not.
5. Save and complete the display setup.
6. Turn off the PS3. Turn off the TV.
7. Turn on the TV. Turn on the PS3.
8. Complete! (Lag eliminated). Please spread this around!
*The key to eliminating ALL LAG is modern LCD's need to be in PC MODE (NOT GAME MODE) On many tv's, PC mode requires you to use a VGA or DVI connector. You'll either need to buy an HDMI adapter or an HDMI to VGA / DVI cable if that's the case.
and the Source MUST BE IN 1080p so that the TV can use it's NATIVE RESOLUTION.* Please, check your tv's native resolution. If you have a plasma that only does 720p, your native resolution is probably 720p. You do not need to follow these steps, it will only make things worse. If your tv's native resolution is 720p, obviously you want to keep your display settings at 720p on your PS3. If your native resolution is 1080i, you shouldn't go selecting 1080p. If your native resolution is 1080p on your TV, you need to be aware that removing 720p as an option will force many games into 480.
Keep these things in mind and remember that the steps above are far from a cure all solution. .
Lag gone! Worked for me! (SAMSUNG LNA52850)
Source : http://answers.yahoo.com/question/index?qid=20081225141902AApX7cJ
Posted on Dec 29, 2008
How can I hook up my ps2 to my Philips Magnavox TV?
First, you'll need a PS2 composite AV cable (Red, yellow, and white cable). If you don't have one, you can get one on Amazon for pretty cheap. (http://www.amazon.com/PlayStation-2-Composite-AV-Cable-PlayStation2/dp/B00004U8QX)
Next, plug the flat end of this cord into your PS2, and the red, yellow, and white plugs into their corresponding outlets on the TV. There may only be yellow and white outlets on your TV (in which case they will be on the front). Then, turn both the TV and the PS2 on and see if its working!
If you don't have red, yellow and white outlets on your TV, you will need an RF adapter for the PS2. (like this one on eBay (http://www.ebay.com/itm/RF-Unit-Adapter-by-Komodo-NEW-for-Playstation-PS2-PS3-/390624177322)
Hope that helps.
Jul 16, 2013 | Philips Televison & Video
Screen turns blank when i try ps3 games but ps2 games work fine
it sounds like your tv is being classified as insecure (some older models of hd tv as well as regular tvs do not always pass the "test" but will "pass it" on certin other occasions) it means that the ps3 may have determined that the tv can be used to rip the disk, if you are using hdmi try switching to s-video or composite. my ps3 did the same thing. I will try to remember how to fix it. untill then you can try my solution or try sombody else.
Aug 12, 2009 | Video Game Consoles & Games
PS3 is backwards compatible with PS2 games, and USED to play them
In Playstation Store, you should download (for free) the PS2 SYSTEM DATA (something like this).
if you have formated your system, the files were erased, and the games won't play until you download the backwards comparibility files again.
Jul 26, 2009 | Sony Playstation 3 (PS3) Console
I'm trying to hook my PS2 up to my Digital Lifestyle tv. When I hook up the PS2, I can get a black and white image, but I can't get sound or color...
You may be connecting your PS2 with a different cable connection than you used previously.  If this is the case, reconnect the PS2 to the last television that it worked on and change the video connection settings to what your next television is using.  Then power the PS2 down and move it to the next television.  The picture should be fine now.
Jun 06, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
No color when using PS2 on plasma screen with some games
I had the same problem when i bought my LCD tv. Go to wal-mart and but the copnate wires and hook it up that way and it should work
Jan 09, 2009 | Sony PlayStation 2 (PS2) Console
Polaroid LCD 1700 Playstation One games issue
um sometimes u cannot hook s video n rca jacks at same time do not ask why try just using one or other
Dec 02, 2008 | Polaroid LCD-1700 17 in. Television
Ps3
Turn on the PS3 and hold the power button down until it beeps. resetting the display settings.
Mar 03, 2008 | Sony Playstation 3 (PS3) Console
Hooking up playstation 3 to tv
you need a ps3 scart lead. i think the one of the ps2 is the same but check. it should just hook up like a ps2. if you are having any problems with the picture hold down the power button when you start up the ps3 for 10 seconds this runs the optimal screen settings for the cable you are using. but if it is the first time you are using the ps3 it will auto start in set up mode. hope this helps
Jan 09, 2008 | Sony Playstation 3 (PS3) Console
The fix:
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
2,551 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
