Copier konica 2223
Trouble code P-26 what does this code mean?
  • Anonymous Mar 27, 2014
    getting service call code c-1292
    Problem Solver:
  • 5 Answers
The problem is your toner density sensor, either your sensor is bad, someone reset p.m. count without running density reset mode. turn machine off hold down 4 then 7 while turning machine on, select 5 then 1 press start print.
Posted on Jan 06, 2008
Model 2223. What does error F35 mean?
Fuser error the hot part
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 23, 2015 | Konica Office Equipment & Supplies
Toner Level Sensor konica 2223
what about the toner level sensor for the Konica 2223????
Jun 25, 2014 | Konica Minolta Minolta 2223 Laser Printer...
HOW TO RECTIFY THE error code F-88 in konica 2223 copier
check your wiring on your board and maybe its a lost contact, or try to replace a new board
Mar 16, 2010 | Office Equipment & Supplies
Affter adding developer to my konica 2223, How do I reset the machine. (to clear ''routine service req'' on the display.
turn the machine off hold down 4 and 7 key turn on enter 9 0 then the date power off then on while holding 47 again and press 5 1 and start if you dont run the 5 1 you will get an error code and not be able to use the machine
Sep 29, 2009 | Konica Minolta Office Equipment & Supplies
How do i set up a konica 2223 copier to print using it as a network printer
the 2223 does not have that feature if you want a copier that is comparable to the same speed and features you would have to buy the konica minolta bizhub 222 new model or there are a lot of low mileage used bizhub 200 machines coming off lease for sale
Sep 28, 2009 | Konica Minolta Office Equipment & Supplies
Frequent paper jams with my Konica 2223 photocopier
I wish I could help you, You need to call for service for your copier. An authorized dealer or Konica minolta branch service in your area. You might need a fuser unit that the upper separating claws disloge or broken, exit paper detect actuator is broken or disloged, or you need a new developer.
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Jan 16, 2009 | Office Equipment & Supplies
I have a Konica 2223 copier - wont print on edges
check all edge settings .f28 is code for charger corona just clean corona assembly with cerosene oil and change corona wire with new one.
Dec 16, 2008 | Office Equipment & Supplies
Error code 27
The error code p27 the toner density sensor unplugged/dirty/faulty
Any problems please get back to me
thank you
Feb 19, 2008 | Office Equipment & Supplies
489 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
