Question about HP Compaq 6715b Notebook
When I power up the screen flickers for a milisecond and returns to black. The fan runs. The hard drive gives a quick 2 second green followed by two pulses of amber for several minutes and then just quits
  • 184 Answers
It sounds as if you have one of two possible problems, either the light tube in your screen is burnt out or windows is unable to load the video driver. When you see the HD green, it means the drive has started, the amber indicated it is working to load the operating system and then it stops - basically indicating it has found something it cannot load or is missing some files or is possibly busy. If your screen shows either the logo or the boot up screen (black with white letters usually), then the screen is working and it is a windows problem. Occasionally on updates or hardware changes it will take windows 5 minutes, up to a half hour at most to load - if you have a flashing cursor in the upper left corner of the screen, try just waiting to see if it will eventually load.
Posted on Oct 02, 2009
Why is my Sony VAIO VPCEB33FM green power light flashing?
It won't be the cpu. If it was, nothing would happen. I would look for a GPU issue, possible over heat.
Jan 01, 2015 | Sony Vaio Vpceb33fm
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
Dell E173FP flashes on for a second on/off switch is constant green
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Jul 10, 2012 | Dell E173FP 17" LCD Monitor
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
My Gateway Gt 5220 will not turn on. Technicaly it does turn on ex: hard drive spin processor click couple time power brick and processor fan spins hard drive light flickers couples time and cd drive will...
sounds like your system is booting up and running due to the hold power shutdown procedure. you might try replacing the video card or adding one if your video is integrated.
Dec 23, 2010 | Gateway GT5220 PC Desktop
My samsung r519 wont turn on. when i press the on button i here the fan going, yet the screen stay's black and only the power light comes on. what could the problem be?
Does the fan stay running? if it does! it is probably a motherboard issue, if the fan is working correctly it should wind down, and if the hard drive is working "hard drive light will flicker" hook a external monitor to the video output on the back of your laptop if you see windows boots up then it would indicate laptop screen problem, but if the fan and the power light are the only activity then the motherboard is the problem.
Dec 22, 2010 | Computers & Internet
Black screen on booting my Compaq 610 notebook
If it seems like you're accessing the hard drive (drive light comes on, flickers intermittently, then goes off, it's a good chance your screen is bad.
First thing to do is plug in an external monitor and start up the laptop. If it comes up with windows, you know it's the screen.
To find out if it's the backlight, or the lcd, toggle the monitor function and shine a flashlight on a slight angle to the screen. If you can faintly see what was displayed on the external monitor, then the backlight inverter is probably bad.
If the external monitor didn't come up, you're probably looking at a motherboard.
The good thing is that all of those are covered for one year under Compaq's warranty, on a new machine.
If you are able to use the external monitor, back up your data, because HP/Compaq usually reformat the harddrive. Additionally, if you've added memory, pull the cards. They want it sent back the way it came from the factory.
Jan 09, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Compaq R3000 laptop screen went black
Give this a try -
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Let me know if it doesnt work.
Jan 20, 2009 | Compaq Presario 2190US Notebook
On powering on'the screen remains black and the ethernet plug is flickering. no sound from the hard drive
the hard drive could have failed..Try a hard start to see if it will react. Do you get any beeps?? a warning beep or beeps may indicate a hard drive failure. Try to get into C-Mode set up. click alt/cntrl/del as you turn on the set.or alt/cntrl F10. Hard drive failures can happen if ther is to much written to the drive or just a plain 'Crash'.
Oct 14, 2008 | HP Computers & Internet
Doesnt power up
Most common problem is inverter board.
Dec 23, 2006 | Proview PL 566s 15" Flat Panel LCD Monitor
HP Compaq 6715b Notebook Logo
193 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
