Question about Toshiba 2060 Copier
I experience a f-28-1 and f-26-1 code on when it start to warm up
When swatch my machine on and it start to warm up immediately that it will turn to please call service f-28-1.
    Guru:
  • 389 Answers
Fuser sub-thermistor open. User problems. Reset required. Turn off power. Hold "0" & "8" keys while turning power on. Then press "8". Then press "9". Then press "print". You will read "3" in the display. Using the # keys, press "0" & "9" at the same time
Posted on Oct 03, 2009
The shaft is not turning . The machine just clicks.
If you have chosen whole wheat setting (and even on some machines just regular white bread) your machine may not start mixing immediately. They warm the ingredients first. Black and Decker machines are like that. If your machine hasn't started mixing within 1/2 after you pushed the start button then you have problem. Give it at least that half hour before assuming there is something wrong. The clicking sound you hear is the heating element gently warming to get the ingredients to the perfect temperature.
Apr 01, 2015 | Cuisinart CBK-100 2-lb. Bread Maker with...
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Wont switch on
Better bring it to a technician to check if the problem is the FUSE or the UPPER LCD screen.
That parts if broken, the system will not start. It needs to be handled by experience technician.
Hope that helps!
Dec 30, 2011 | Nintendo DS Lite Console
I'm looking at the Pattern Selector Dial. 2 different stitches are shown for each selection A - H. 1 shown in blue 1 shown in green. Does each pattern have 2 options?along the rt side of the machine also...
i have same machine, you know i found that to be odd too. heres what you do, click it to the letter you like the style, then start sewing on a swatch at the very shortest stitch. then start increasing the stitch width more and more, up to 4 and see how it difers. i think thats where you will see the difference. i haven't played too much with mine yet, but listening to you is encouraging me to play on a swatch with all the difffernt styles you can stitch.
Jun 17, 2010 | New Home 2014LE Mechanical Sewing Machine
How to change a swatch beat watch to 12 hour from military/24 hour time
Go to the Swatch web site "www.swatch.com"
Select "watches"
Scroll down to "Customer Services", select "manuals"
Select and download the manual for your watch.
Jan 01, 2010 | Swatch Watches
PSP X2 Swatches in Materials Properites windows suddenly all turned black. Moving picker through the color wheel changes RGB and HSL number values but the Current, Previous and Swatches all remain black. ...
I had the same thing happen. When I re-calibrated again using the monitor calibration (under color management) I again got swatches displayed in their proper color.
Sep 22, 2009 | Corel Paint Shop Pro® X Full Version for...
Minolta DI200 Error Code 00070
try and take the toner bottle out and turn machine on and than put the bottle back.it;s bottle sensor problem.good lock
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
Singer futura ce-200 tension problem
stop, remove all threading, clean machine,be sure to clean the top tenion disks with a thicker thread, change needle, rethread carefully and try a test swatch. If not working still, your tension could be out of adjustment. Adjust top tension until the top thread of your swatch balances with the bottom. Use two contrasting colors of thread so you can know which tension is wrong,
Remove bobbin and dangle by the thread, it should not move untill you jerk it and should drop about 3-4 inches. Adjust small screw until this works. Try another swatch.
Oct 26, 2017 | Singer CE-100 Futura Computerized Sewing...
Error Message: "Contact Your Dealer Printer Error E04-01" - What does that mean?
you can try a LBP fuser reset and LBP error log clear . this might fix the problem your having.
Mar 14, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Swatch TDA03-1US Answering Machine
try putting 01 into your analog phone after you have put in your 3 digit pin code
how do you put in your pin code we have lost our operators manual
Jan 16, 2008 | Swatch TDA03-1US Answering Machine
162 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
