Question about Canon DC20 DVD Camcorder
Canon DC20 My camcoder no longer wants to charge. The charge light won't come on with either battery. Is is the ac adapter?
  • 64 Answers
This happens alot at work its either the charging part is broke or its the mainboard inspect the port for damage if its ok then inspect the ac adapter for damage as well, if you have time you could go to best buy and ask to use a charger from a floor model if it doesnt work then it needs to go in for repair sorry.
Posted on Dec 22, 2007
Won t charge new battery
Few options: either the connection is "hazy" (try moving the plug in the hole), battery is fake or battery has been abused and is empty...
Aug 16, 2013 | HP Mini Computers & Internet
Dell inspiron not charging
Dear Mathew,
You should you Dell Utility and it has the function called Dell Battery Metter, it can enable or disable charging
Nov 12, 2012 | Computers & Internet
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
My sp will not charge, I am not sure if it is the battery or something else
Game Boy Advance SP - Charging Light Won't Display If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
    Troubleshooting Steps:
    1. Make Sure the Game Boy Advance SP Isn't Already Fully Charged
      If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
    2. Make Sure the Outlet You Are Using Works
      Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
    3. Try a Different Licensed AC Adapter
      If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
      • If a different AC Adapter works, you will need to get a replacement AC Adapter from our Online Store, or by calling our Consumer Service Department at 1-800-255-3700.
      • If a different AC Adapter doesn't work, or if a replacement AC Adapter is not available and the lights will not display, we recommend having your Game Boy Advance SP repaired. Check out our convenient repair options.
    Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
Sep 02, 2011 | Nintendo Game Boy Advance SP Console
It will no longer charge or turn on
You might want to check the battery,if the battery is completely dead it won't charge or turn on
Jul 04, 2011 | Canon DC20 DVD Camcorder
My AC adapter suddenly can't seems to be able to charge my battery. Please kindly advise
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 08, 2011 | Compaq Presario CQ40 Series Laptop Charger...
Canon DC20 wont charge or turn on.
I wouldnt buy a new one when we get ones that are water damaged we throw them away and dont reuse anyhting sorry.
Dec 26, 2007 | Canon DC20 DVD Camcorder
AC-V16A
Your'e Battery is damaged, thats all.
Gr Diver
Dec 15, 2007 | Sony Handycam CCD-TRV11 8mm Analog...
Canon DC20 DVD Camcorder Logo
112 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
