Question about Canon imageCLASS D880 All-In-One Laser Printer
Hi I have a paper jam at the fuser rollers on a Canon ImageClass D861. I can't figure out how to get at it. Can you help?
  • 56 Answers
You accually need a new fuser unit and to take it out its quite a mission.
you need to remove in this order:
the drum unit
the left panel holding the glass
the glass
where the scanner is there is a black thin guide holding the ribbon cable...take that off.
the display panel
bottom left side panel
bottom read side panel
bottom top panel
flip over the black milar cover over the power supply.
disconect the 3 cables
move the platern about half way and you will see the holes on top of the platen aligned to the bottom so to get to the 3 screws holding the fuser unit.
undo the screws with a long star screw driver and slowly wigle the fuser out.
to put it back you do everything in the opposite order.
Good luck
Posted on Oct 09, 2009
How do you take out a paper jam canon ImageCLASS D320?
First you have to know the position of the paper that has jamed.
the cardinal thing to do is to loosen and open doors that must be opened in order to have a clear view of the paper.
How to open see the marks on the machine. Mainly the paper jams between the drum and the fuser, so make sure you see any green nobs meant for seperating the presssure roller and the upper roller so that the paper is free to move out in case it jamed between the fixing rollers.
See the manual on how to remove paper jams.
Jul 12, 2011 | Canon imageCLASS D320 Digital Copier
Some of the springs came off the rollers and a small broken piece of support for roller-do i need to get a whole new fuser assembly?
if you found a spring from the fuser and a flat blade like piece of black plastic this would be a detach finger and tension spring all fusers have the they help prevent the paper from rolling up on the fuser roller. fusers have either 5 or 6 depending on the model.they will funtion muinus one of these. if you get regular paper jams in the fuser of if they start replace fuser
Oct 03, 2010 | Canon ImageClass D880 Copier
Sir my printer is canon mf 4320d sir it appears paper jam on display but i open rear and front cover but any paper is not found jam please help
I had the same issue, Turned out to be a tiny scrap of paper inside the fuser (the thing in the back behind the "caution hot" sticker. It was nearly impossible to see. I removed the screws on the fuser cover (to loosen, it wouldn't come off), then lowered the top lip enough to see the bright orange fuser roller. The paper scrap was stuck on the right side.
Sep 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Paper jam. paper tore at the exit roller. I
FUSER ASSEMBLY NEEDS TO BE REMOVER/REPLACED, THE COST AND LABOR MAY NOT BE WORTH THE REPAIR
Jan 22, 2010 | Canon ImageClass D660 Copier
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
PAPER JAM ON LEFT SIDE, PAPER DOES NOT COME OUT
Open the left cover and inspect the paper tray and the fuser unit.90% paper jam in the fuser/exit unit.Inspect and clean the rollers and the fingers.
Oct 02, 2009 | Canon imageCLASS MF6590 Copier
Paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam
Your best bet is to have a canon tech check this problem out. There are several causes for this issue; a bad delivery roller, a small piece of paper lodged out of sight. Canon help is 800 ok canon.
Jul 09, 2008 | Canon ImageClass D861 Printer
Canon imageCLASS D880 All-In-One Laser Printer Logo
224 people viewed this question
old marine
old marine
