I Have a Ricoh Aficio 1224C Colour Photo Copier which is networkable with a newwork cable, I would like to install this on my basic network running 5 laptops and 3 Desktops Via a BT Hub (Router) If i Pluged the photo copier into the last port on the Router would i be able to pick the photocopier up on the network, and install the photocopier on each machine Via the installation disk? If so? if their any particular settings I need to work out? Like IP addresses and Sub Masks, or can it work dynamic?
  • Dan Cawthorne Oct 02, 2009
    Wiz, My Networking skills need to be improved a lot, so when you say hosts i assume you mean anything that as an IP,
    So the simple solution is to define static ip addresses to every host. do i need to define any settings with in the router?
    President:
  • 3,085 Answers
Static IP's for the copier and all hosts. Won't work reliable with DCHP
Posted on Oct 02, 2009
Testimonial: "Thank you for the keep response, Rather Brief Solutions"
  • Leroy Elliott
    Leroy Elliott Oct 02, 2009
    Easiest way is to use the same scope as your router.
    Subnet Mask is 255.255.255.0
    Such as:
    192.168.1.120
    192.168.1.121
    192.168.1.122
    etc.
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
How do I scan a document from my Ricoh 1224c copier to my computer?
have you installed the driver for its scanner? here's the link http://www.ricoh-ap.com/downloads/GetDriver.aspx?CID=1&pn=Aficio%u2122%201224C&path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/c24_32/c24_32en.htm
Sep 02, 2011 | Ricoh Aficio 1224C Black and White Copier
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh (Aficio) 1224c. code sc670 we want to decode this codesc670
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
Aug 03, 2011 | Ricoh Aficio 1224C Black and White Copier
How to reset pass admin RICOH aficio 1224c?
The user ID is blank. The password is the word password.
If that doesn't work, let me know.
Mar 14, 2009 | Office Equipment & Supplies
Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Jun 18, 2008 | Ricoh Aficio 2015 Copier
Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Jun 18, 2008 | Office Equipment & Supplies
180 people viewed this question
jasbo
jasbo
