Question about HP Photosmart C6180 All-In-One InkJet Printer
Lines in paper when scanning - HP Photosmart C6180 All-In-One InkJet Printer
    Genius:
  • HP Master
  • 1,479 Answers
If you're getting white lines on your scans it usually means one or more of the lamps are out.
Posted on Oct 02, 2009
Line comes up vertically on scanned paper on colored paper only.
have you tried to uninstall the last upgrade? Sometimes they're not working as expected
May 29, 2015 | Office Equipment & Supplies
When I scan a white or Blu or green line on my paper scan show
It might be that you need to clean the printer heads. Your manual should tell you how to do that; also you might be able to Google an online manual for you printer model.
Jul 04, 2014 | Konica Minolta bizhub C450 Scanner
Equally spaced lines across page only on color copies
If not in the direction of the paper feed then in the direction of the scan head. Dirt on the scan head or bad scan head or scan head connection. Send it back.
Nov 15, 2013 | Konica Minolta Bizhub C284 Color Copier /...
Black line 1 inch wide right side ,when copies are made and faxing
When the paper is fed through Automatic Document Feeder (ADF) is is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying!
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Also note that your machine can scan an image only 8.15 inches wide, regardless of how wide the paper is.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Brother 5750E Fax
When I scan to printer the page comes out with short lines down 1 side
If your printer has both an automatic document feeder and a flat glass portion for scanning, try scanning from both. If you only get the lines on one of the scans then that is where your problem is. Most common issue on scanners is a liquid paper, bit of paper, glue, etc on the Automatic document feeder glass. Clean the glass and you should be fine.
Apr 02, 2011 | HP Office Equipment & Supplies
Black line in paper
On what operation are you receiving the black line in your paper?
This problem usually appears when you try to scan or copy using your ADF (automatic document feeder).
To remove this black line in your paper, clean the ADF platen glass in your printer and do as well in the flatbed scanner glass. This ADF platen glass can be found right below where the documents in the ADF goes through. Its a glass about 1 inch in with and beside the flatbed scanner glass (the one where your documents is lay down for copying and scanning. Dried ink or paper residue sticked in the glass can cause this line in the paper. Clean it with a a clothe and spray some windex on it.
Feb 10, 2011 | Panasonic KX-FLB801 All-In-One Laser...
When I scan a document, a black line the length of the page is seen on my scanned copy. What is causing this? I have cleaned the print head.
When you are scanning with the auto paper feed, if the scanning window has a spec on it, you get a line the lenght of the paper.
Feb 17, 2010 | Brother MFC-685cw InkJet Printer
3050
when we copy or scan we get lines at both side throught
the paper
Apr 15, 2008 | HP LaserJet 3050 All-In-One Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
54 people viewed this question
Seeker5211
Seeker5211
