Question about GE Dishwashers
The soap in my dishwasher clumps up and does not disperse.
  • 3 more comments
  • igk1927 Oct 02, 2009
    o.k-- .I understand about clearing out clumped soap, but what is involved with loading dishwasher correctly? I have had the dishwasher for a couple of years. It never did this before.
    What can prevent water from getting to soap?
    I understand about cleaning out clumped soap, but don't know what is involved in "loading dishwasher correctly."
    I have had the dishwasher for at least a couple of years and it didn't do this.
    What could prevent water from getting to soap?
  • igk1927 Oct 03, 2009
    If the dispenser cup is open when the dishwasher stops running (but still has clumped soap in it) can the problem still be with the cup? How can I tell where the water comes from so as not to obstruct it with loading? I have had this dishwasher for a couple of years and my loading style has never caused problems before. However, I am open to loading instructions. Where can I get them?
    I am using a GE dishwasher, a small size as i live in an apartment. I will have to look up the manual later in the day. If I still have trouble, can I get back to you?
    Thank you. Will have to look up manual and get back to you later in the day.
  • 215 Answers
It might be due to drain trap will have some kind of block
Clean out the dishwasher's drain trap. All kinds of food and debris can accumulate there, as well as clumps of undissolved dishwasher soap. Your dishwasher's owner's manual will contain instructions to clean it.
which company and model you are using?
Hope this helps
Thank you
Posted on Oct 03, 2009
    President:
  • 1,714 Answers
Make sure that you are loading the dishwasher correctly. Water not getting to dispenser. Clean dispenser hinge and make sure it's not obstructed with clumped detergent.
Posted on Oct 02, 2009
  • Craig Butler
    Craig Butler Oct 02, 2009
    Possible loading..?? This is just a suggestion. There are other possibilities, possible solenoid failure for the dispenser cup. I am trying to eliminate possible causes. I have to start somewhere.
    Go to another expert.
3 Suggested Answers
zeusfaber
  • 247 Answers
SOURCE: GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Posted on Apr 22, 2007
SOURCE: Dishwasher problem
I too have had this problem>It would only occur in times of no hot water, or delayed hot water operation.If your hot water heater is a long way from the washer this can happen<eventhough it doesnt seem to happen consistantly>the solution would be to try to run the hot water in the sink nearest to the washer until it gets hot,then start the dishwasher. The soap despenser is one of the first steps in the proccess,and if the hot water had not been run in a while it could take up to 3 minutes to reach adequate temp>good luck hope this helps
Posted on Dec 31, 2008
I ran a load through it sounded like the water went through,but the soap was clumped up at the bottom of the washer
sometimes the soap dispenser latch gets hung up if there is too much soap in it, I recommend using the premeasured cubes. The second thing that may cause this is a
failed fill valve, but you have already mentioned that it was filling. It is very unusual
for the soap dispenser to fail but it does occasionally happen and it must be replaced
as a unit if this is the case. Hope this helps.
Jul 10, 2011 | Frigidaire FDBB1940D Dishwasher
Soap compartment does not open and allow soap to disperse
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 24, 2010 | Frigidaire Dishwashers
The dishwasher will not go through the cycles completely . The soap dish does not disperse the soap . The water is no draining completely
heatman101
Aug 28, 2010 | Asko D1776 Built-in Dishwasher
The dishwasher does not drain and the soap door opens but we are left with just a big clump of wet soap in the cup.
If the DW does not drain the pump could be clogged or has failed. That would also cause the spray arms not to rotate and not circulate water to dissolve the soap or clean the dishes
Aug 26, 2009 | Dishwashers
PDW7300 Dishwasher leaves clumps of soap in the dispenser after wash cycle
have you tried a different brad dish soap?  Is the water getting hot enough?  Is the water valve opened completely?
Mar 15, 2009 | GE PDW7300N Dishwasher
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Rinsing detergent from dispenser
Use gel run a few cycles and help clear and then don't overfill w gel soap
Nov 13, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Soap Not Mixing
Inside the soap holder there is a small spring and sometimes that comes under causing it not to open during the wash. If that is fine and you are using liquid soap try pulling a cople glasses of hot water on the latch and give it good clean because it soemtimes gets jammed up. Anymore questions give me a shout.
Jul 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Dishwashers Logo
191 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
