SOURCE: xerox xd100
There are a few things to try. If you have been using the device, I'm certain the first one is not it, but power off the machine. Look on the left side in the middle near the top. If there is a silver screw in the device, that needs to be removed. It is the shipping screw to hold the scanner in place when you are moving the device. Next, check your power source. Power off the device and plug it directly into the wall outlet, not into a power strip. The wall outlet needs to be grounded as well. Still have the code? Try the following (this is from the xerox.com support website)
Performing a Fault Reset 1 01 will reset your Scanner, and allow you to check the Scanner for broken parts as it moves.
If this does not work, you probably need to have the device serviced.
SOURCE: Printer is not printing at all, just blank pages
I can help you troubleshoot your printer. Just be prepared if your printer never prints again. This is rare to say the least. I just want you to know that in advance. OK? Laser printers use a static charge applied to the paper to represent your document and then this charged paper passes over the toner and finally the toner on the paper passes under a tungsten wire heated up high enough to melt the toner into the paper. This is why newly printer pages are warm to the touch. So, with three systems doing the magic any one of them can fail due to fatigue.
To start with, when was the last time you changed the toner cartridge?
How old is your printer and how many pages per month has it printed so far, on an average?
Are you under warranty any longer?
Thanks.
Worldvet
SOURCE: system fault
too many black copies, keep black copies down to 400 at a time and break it up with colour jobs
SOURCE: Xerox 8500 - overprinting when double-sided
That normally is caused by a dirty maintenance kit. Often times they dry out and do not put enough lubricant on the drum, I would start with a new mainteanace lit., you may also have a bad wiper blade, although thats less likely.
SOURCE: Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
