Question about Toro Garden
Primer button how to replace primer button on the curved shaft trimmer model no 51952 manual does not show
trippssmengi
  • 76 Answers
SOURCE: replace a flexible curved shaft
If you go to www.homelite.comin the red area up top click on order parts then click - click to launch homelite parts catalog, then scroll down thru agreement and click agree and then you will need to know your model number and you can get a breakdown of your trimmer wich will give you a good idea of how your machine is put together.
Posted on Jan 05, 2009
SOURCE: Homelite curved shaft timmer line problem
It sounds like its a bump feed which they usually are, try turning on the machine and bump the head off the ground. If this fails to work try rewinding the line on tightly and neatly with no parts of the line crossing over as this could knot it. Quick tip most heads have a arrow pointing the direction to wind the line.
Let me know if that works.
Posted on Jan 09, 2010
  • 41 Answers
SOURCE: Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Posted on Apr 14, 2010
  • 4 Answers
SOURCE: Trimmer won't start
The fuel line may not have a good seal to the fuel tank.
Posted on Jul 11, 2010
rycgl
  • 1545 Answers
SOURCE: Owners Manual for Echo GT200R straight Shaft Gas Trimmer
Maybe go to Echo's website and check with them.
Posted on Jul 13, 2010
Primer bulb on weedeater sticks after primeing
The primer pulls fuel from the carb, so if it sticks in there is a blockage in either the fuel filter in the tank, or in the carb itself, or the hose is trapped.
Sep 09, 2012 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
I have a 26cc ryobi weed trimmer--primer bulb will not draw fuel, but will draw fuel when I loosen the 2 screws that hold down the bulb
Possible issues:
1. Primer bulb or bottom assembly has crack or hole in it (needs replacing). See ebay for about $6.00
2. Fuel lines are not sealing to the primer nipples properly (cut line and re-attach if you have sufficient line available) otherwise; replace.
3. You may be somehow kinking the fuel lines when you clip it back in place due to fuel lines too short
My bet: #1 or #2. Good luck!
Sep 17, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a cs30 ryobi weedeater and something in the shaft is causing the weedeater to either stall out or completely shut off, how can i fix this problem?
Usually this is a fuel supply problem. It can be caused by a cracked fuel line, debris in the fuel tank of in the tank to carb fuel connection. If you have a primer bulb a pin hole in the primer bulb or (if so equipped) the line that goes to the primer bulb it will do the same thing. Small air leaks will cause the trimmer to run fine at idle but anytime you demand more speed it just will not speed up or it will stall. Additionally the diaphragm in the carb can also have a small hole or tear in it. (Located under the 4 small screw plate on the carb)
A problem in the shaft is rare unless the shaft itself breaks or the internal flexible drive shaft has a partial break and the spring material is unwinding. If this is the case the flexible drive shaft will have to be replaced. It requires removal of the engine from the curved shaft assy to replace. Once the engine is removed the shaft is supposed to just pull out. WHen installing a new shaft you must make sure the 4 sided drive spline drops into the string head or you an not install the engine correctly. The same goes for the engine to shaft mating area. Align the 4 sided spline.
Thanks for choosing FixYa.
Kelly
Sep 08, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My prime button broke can i bypass it
No, you cannot bypass it. Even if you could get it to run without the bulb there would be a significant chance of fire and injury. Replacement Ryobi primer bulbs are very common, you can get one just about anywhere...in fact, you can go to Google, put in Ryobi and whatever the model number is of your trimmer and the words primer bulb and you will get plenty of hits for parts companies that carry the replacement bulb.
Sep 15, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Model No. 7754-EZ Bulb is shattered - leaks Won't pump gas
You'll need to replace the primer bulb (not very difficult) if you know the part number go to ebay and type it in and you should get some hits.
good luck!
Mike
Jul 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Primer sticks in on gas trimmer
Primer bulb assembly should unscrew. If you do that and then replace it back on the unit does it do it again? Seems that a vacuum is forming in the primer bulb. Reed valve could need cleaning.
Jul 15, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a 22cc Mcculloch gas trimmer. I believe the model is 3315.
The screen in the carburetor might be clogged, blow it with compressed air, reinstall it and see how it goes.
Jun 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
88 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
