Question about Dirt Devil SwivelGlide Bagged Upright Vacuum
Swivel glide has no suction in the hose but seems to have a bit at the head, definatly not alot. can i fix this myself somehow?
    Scholar:
  • 35 Answers
Get ahold of a plumbers snake, disconnect the hose and run it through unclogging it .
Undo hose and see if there is suction right at the socket where the hose plugs into to see if there is suction there.
Inside the place where the bag goes, at the bottom there is a motor dust filter, see if it is clogged.
Also at the beatter brush, make sure that there is not dirt crammed around the nozles input, and check to see if the belt is not slipping on the beatter bar and remove the wound threads from the beatter bar it self.
Best!
Robert!
Posted on Oct 02, 2009
Why havent I got any suction or am able to stretch the hose when i use the hose part of my dyson dc40
blockage in the suction head
could be paper , hair , material or something large like a small ball etc
it will be stuck up in the swivel joint of the tube
May 11, 2016 | Dyson Vacuums
Plenty of suction with hose off, little suction with hose and head on. No clogs in hose or head.
if it works without the hose attached but not with it on , then there has to be a blockage keep looking for it .
May 10, 2016 | Miele Vacuums
What to do if Vacuum losses suction?
There may be leakage somewhere in the intake path.
Jul 15, 2014 | Dirt Devil Vacuums
How do i detach hose to remove blockage?
Lift the hose out as if you were going to use the attachments. At the base of the hose there is a swivel to adjust the hose 90 degrees. Where the lower section of the hose attaches to the swivel you will see that if you give the hose about a quarter turn then lift, it should come off to check for blockage. Also check the rear suction port located near the hose swivel for blockage. It resembles a parallelogram in shape and come off with 2 visible plastic screws.
Apr 27, 2012 | Miele S7210 Bagged Upright Vacuum
Beater attachment has no suction.
Your hose issue is isolated from the garage. You have a switch problem in the handle of the hose.
If the hose has a swivel handle your problem will lie in the switch itself or the contact rings within the lower portion of the handle itself. If this is a light gray hose with swivel handle several years old switches were an issue from time to time . The problem can normally be fixed by replacing the internal wiring harness in the hose.
Oct 03, 2009 | Easy Flo EF1600 Central System Vacuum
Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
May 03, 2009 | Dirt Devil SwivelGlide Bagged Upright...
Dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Apr 11, 2009 | Dyson DC14 All floors Bagless Upright...
Samsung Quiet Storm 9048R hose break
OK ART THE FITTING THAT CONNECTS TO THE HOSE SHOULD HAVE TWO SMALL SQUARE HOLES OPPOSITE EACH OTHER YOU NEED TO PUSH TWO FLAT HEAD SCREW DRIVERS IN AT SAME TIME TO RELEASE THE SECTION THAT THE HOSE SCREWS INTO POP THIS APART THEN REMOVE THE SMALL PIECE OF BROKEN HOSE AND SCEW HOSE BACK ON REPLACE INTO FITTING SO THE SQUARES POP BACK INTO PLACE AND START VACUUMING HOPE THIS HELPS GLENN PS ANY VACUUM SPECIALIST WOULD BE ABLE TO HELP WITH THIS SMALL PROBLEM IF YOU WANT TO MEET ONLINE ABOUT THIS I WOULD BE MORE THAN HAPPY TO ASSIST
Nov 14, 2008 | Samsung 5528R Vacuum
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
Miele Vacuum cannister
Most times you have to replace the neck on the powerhead. Sometimes the switch in the handle of the hose will have a bad solder connection. But S300 is not a good model number, also the powerhead has its own number on the bottom, so couldn't look up parts for you.
Feb 21, 2008 | Miele S300 Bagged Canister Vacuum
Dirt Devil SwivelGlide Bagged Upright Vacuum Logo
110 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
