Question about Agri-Fab Agri - Fab Snow Blower - 42"
Traction Belt (new) continues to slip off of drive plate.
I have a Toro Snowblower Model#38620 (826LE). Last winter the Traction belt(94-8812) kept slipping off of the pulley-impeller when under load so I replaced both belts which were worn. I purchased from a Toro dealer including the Auger belt (#106-4498). The traction belt continues to slip off underload. The traction cables are adjuster correctly. Can you help me?
What are the belt sizes for a craftsman snowblower model# C950-52379-5
Based on the following info from SearsPartsDirect.
Will this fit my Craftsman Canadian model c9
The auger drive belt is part number 585416MA, and the drive belt is part number 1733324SM.
Feb 09, 2015 | Craftsman Garden
The traction belt on my Toro 824XL 38083 broke and the new belt came off after only 10 minutes. The tensioner was in the correct position with the belt on the inside.
My first question is how old is the machine? Now if it consumed the belt in short order I would start by checking to see if there is any gear lube left in the transmission as that does need to be changed and topped off periodically as seepage does occur and if the unit binds up the belt will not stay attached. Now given this is a Snowblower by all means check the Bearings on the end of the Auger and make sure they are not binding since even a new machine can get some moisture in those bearings and they will not turn. Then make sure the bearings on the wheels have not been compromised and are binding up the unit as well. In front of the Friction Disc there is a Hub Assembly and that as well could be binding so with the belt off see if it turns freely.
Feb 07, 2015 | Toro Garden
Had work done last winter because drive belt kept coming off...Found the two bolts that hold transaxle in place kept falling out, also the plates that bolt over axles were worn/broken...have items rep
I own this model, I have not experienced this issue,something is causing excessive vibration to cause this issue ....a bad belt,misalignment or a sheave that is bent !
Sep 23, 2014 | Husqvarna Lawn Tractor  25 HP 54in Deck...
Change belt on snapper 722 snow blower
1. Remove the belt cover with a socket wrench. Slide the belt cover off and set it aside.
2. Remove the two belt cover stud bolts with a socket wrench to get to the auger belt guide. 3. Remove the belt guide with a socket wrench.
4. Push down on the belt tensioner pulley with your hand. Remove the old belt and set it aside.
5. Install the new belt and release the belt tensioner pulley to tighten the belt.
6. Re-install the belt guide with a socket wrench and tighten the bolt.
7. Re-install the two belt cover stud bolts and tighten with a socket wrench.
8. Re-install the belt cover and secure it with the cover bolts. Tighten the bolts with a socket wrench.
I pulled the following from a snaper model similar to yours.
The snowthrower has two drive belts, one for the traction
drive-which transmits engine power to the wheels, and
a second for the auger drive-which transmits engine
power to the auger mechanism.
Each of these drive belts are of special construction and
should be replaced only with genuine replacement belts
which match the original equipment belts. These are
available from your dealer.
Traction Drive Belt Replacement
I pulled the following from a snapper model similar to yours. Believe it should help.
1. Disconnect spark plug wire and fasten it away from
the spark plug.
2. Remove belt cover. (Located in back of the discharge shute).
3. Pull the traction drive belt idler pulley arm (See
Figure 24) away from the belt to relieve tension, and
slide the belt off the engine pulley.
4. Slip the belt off from around the traction pulley (See
Figure 29) and pull the belt out of the unit between
the auger pulley and the traction pulley (the lower
cover need not be removed for this step).
5. Reverse the procedure to install the new belt. Be
sure there are no twists in the belt, and that the belt is
properly seated in the pulley grooves.
6. Replace the belt cover.
7. Start the unit, and check the traction drive for proper
operation. See "Traction Clutch Cable Adjustment"
for adjustment procedures.
There are also several videos on YouTube on changing snowthrowr belts. (Didn't see one for your blower, but most similar and should provide a good starting reference).
May 09, 2014 | Agri-Fab Agri - Fab Snow Blower - 42"
I have a toro ccr 2450 snowblower. i bought it
No if your belt is shredding there is something rubbing on the belt. Check the idler/tightner pulley see if it spins freely. Check make sure nothing but the pulleys are touching the belt when it is engaged.
Sam
Jan 08, 2010 | Toro Lawn Mower With Toro Power Tools
Snowblower wheels wont engage when they are on the ground they move slowly when I lift it
1) Traction drive belt slipping or worn
a) idler pulley not fully engaging
b) cable/lever adjustment
c) spring missing or broken
2) Friction drive disc slipping or worn
a) rust on hexagon shaft not allowing friction disc to move
b) missing or broken engagement spring
3) clevis pins missing or broken on wheels
4) roll pin on drive shaft missing or broken
inside the cover for the gearing mechanisms, chain drives, gears ect.
Dec 06, 2009 | Ariens Garden
Snowblower Treads not turning
Hello, if you go to searspartsdirect.com type in your model number you will be able to find a diagram that will show you where and how the spring attaches
Mar 05, 2009 | Toro Blowers Rake and Vac - Electric...
Agri-Fab Agri - Fab Snow Blower - 42" Logo
200 people viewed this question
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
