Question about IBM ThinkPad R40 2722 Notebook
No sound inspite of checking all parameters .Have tried all methods. two months back there was total system crashed, window were loaded again, since then loaded all drivers required to get sound back but no luck.
  • 184 Answers
Be sure that you have the correct sound card driver, if it uses an AC97 driver there are several different versions, also check that the sound did not automatically mute itself. Check the bios that the sound card is enabled.
Quite often the "recovery disk" that comes with the pc will reload windows and with generic sound and video drivers, they have to be replaced with the exact driver for the hardware the pc has - the best bet is to remove the old drivers first then go to IBM and look up the exact model number and see which drivers are recommended or available, usually also the IBM site will list the possible drivers for sound and they are usually available from the manufacturer site. Here's the link for IBM http://www-307.ibm.com/pc/support/site.wss/MIGR-46024.html
Posted on Oct 02, 2009
Code Error0x0000073
found this on net
STOP: 0x00000073 (parameter, parameter, parameter, parameter) CONFIG_LIST_FAILED
Explanation: This is a Windows 2000 Executive character-mode STOP message. It indicates the system configuration link list failed. One of the core system hives is corrupted or unreadable, or some critical Registry keys and values are not present.
User Action: If this is the first time you have booted after installing new hardware, remove the hardware and boot again. Check the Microsoft Hardware Compatibility List to verify that the hardware and its drivers are compatible with Windows 2000. For information about the hardware, contact the supplier. If you are installing Windows 2000 for the first time, check the Windows 2000 system requirements, including the amount of RAM and disk space required to load the operating system. Also, check the Hardware Compatibility List to verify that the system can run Windows 2000. If Windows 2000 is loaded and no new hardware has been installed, reboot with recovery options set to create a dump file. If the message continues to appear, select the Last Known Good option when you reboot. If there is no Last Known Good configuration, try using the Emergency Repair Disk. If you do not have an Emergency Repair Disk, contact your technical support group.
Nov 19, 2013 | Computers & Internet
Upgrading from vista to win7
I would start by deleting partitions and doing a full format. Then loading an OS. Check MS minimum system requirements for OS and double them.
If it crashes again. Start checking RAM.
Sep 27, 2012 | Dell Computers & Internet
Syncmaster 2333- connected fine to laptop on docking station for 3 months. Then all of a suddent it is causing my laptop to crash. laptop works on its own. Connected, the monitor shows my encryption...
Disconnect the monitor from the docking station and plug it directly in the laptop connector. If all is well it might be the docking station. I had one crash a computer and had to rebuild the operating system to make it work again.
Mar 09, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
My Toshiba laptop just crashed. It is 2 months old. Does this happen often?
If only two months old, you are probably using Vista. On the toshiba, you can hold down the power button for a few seconds and it will turn off the unit. If that doesn't work there is a small hole near the power input that is a reset button. You need to use something like a paper clip to push into the hole to reset. After a few seconds try turning the thing back on. If you cannot get it to come back on, then you need to take it back to the seller to get benefit from the warranty. Sometimes windows xp and or Vista, just get hung up, and the only way to get it back to normal is the process shown above. Good luck.
Sep 11, 2009 | Computers & Internet
Will not boot
It can have boot virus and when booting it finds your antivirus soft and if cant stop antivirus then calls "crash" screens, also sometimes real crashes heppened vith driver incompatible or incorrect parameter stored. If you have any LIVE Windows CD or linux boot from it anc check for viruses, also make disk check with disk utility. If not corrected windows must be reinstalled. If you havent try try "last good known configuration " from bootup screen, to call boot press F8.
Aug 03, 2009 | Toshiba Satellite 1805-S204 Notebook
Acer M3100 crashed
I'd suggest there is a possible hardware error. You need to get into the bios and check the temperatures they'll be under 'system health' or similar. Also might be worth running a ram check. Download 'windiag' it's a microsoft program designed to check your ram and it is very good.
Mar 29, 2009 | Acer Aspire M3100 Refurbished Desktop PC -...
HP 750 desktop pc won't boot up...?
Thank you for contacting Fixya. If its loading operating system then there is no problem with hard drive. Its absolutely a software problem. Please reinstall a fresh copy of Operating system i.e., Windows Xp / Vista whatever. and install the proper drivers for the system. Hopefully it should work. Again if same problem occur then you need to check the RAM. I mean is the system re-boots again and again hten clean the RAM slots or insert the RAM in other RAM slot. There may be some dust inside the slot. Try these steps. Hopefully it should work. Thank you......
Sep 14, 2008 | Computers & Internet
Validating windows xp
dial the 1800 number and MS can give you instructions, its a common fault with Windows Activation
May 18, 2008 | Microsoft Computers & Internet
IBM ThinkPad R40 2722 Notebook Logo
135 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
