Question about Freezers
My Indesit Freezer GSF120 - Like living in a wind tunnel
My Indesit Freezer - Like living in a wind tunnel. It is very nearly always on. It makes a whiring noise and makes me feel like I'm living in a wind tunnel. The engineer I have had round says that all new freezers are now this loud because they have put new ozone friendly gas in. Any ideas?
4 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: my kenmore freezer is making a lous noise that
Is it still cooling ok - or is it going a bit weird ?
It could be the flow control solenoid - that affects where the gas goes - or the compresor motor (big black thing).
If it does not cool at all - it will need a new run capacitor on the compressor.
If it seems to cool ok - but sometimes too much - then suspect the solenoid coil / control for this.
Neither are that expensive.
Posted on Aug 07, 2009
  • 389 Answers
SOURCE: whirlpool upright freezer evl209nbtq making noise
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
heatman101
  • 43501 Answers
SOURCE: hi,i have an indesit fridge freezer its nearly 3
Check out these tips...they can help you figure out whats going wrong...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 12, 2010
Why does the top of my freezer icing up
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Sep 07, 2014 | Freezers
How do i get the plastic panel on teh back of my frigidaire freezer off--there aer no screws--there is a little round button off center on teh panel. I have used hair dryer adn the whole panel comes...
The panel you are trying to remove im guessing is near the top of the freezer. Do not remove that, as it is ONLY an air tunnel that leads from lower down the back wall. Removing this plastic panel could damage it. That METAL panel is held in place by about 10 screws. also, the temperature control is usually clipped on this back wall, and NEEDS to be removed from the back wall to remove the back wall from the freezer. there is usually a styrofoam cover around this control behind the back wall, keep this in one piece. If there is a problem with your freezer, it will have nothing to do with that upper plastic panel, as again, it is only an air tunnel
Dec 10, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
"High wind" sound following defrost.
Freon running through the feon lines can make some odd noises, usually a gurgling or higher pitched noise. If your freezer works fine with no more strange noises, then don't worry about it. If you have temperature problems or continue to have abnormal noises, then see if your freezer has the 5 year sealed system warrantee that most freezers have. If it does, and it is under 5 years, then call Frigidaire to come out to check it out for free. If it is out of warrantee you will need to live with it or replace the freezer, since a freon sealed system repair is very high. Good Luck, Appliance Specialists
Feb 04, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
My indesit freezer in on amber light on 1 and it is too cold should the light be showing amber
check to see if you dont have unit on quickfreeze.or possibly the thstat is set to high or control is faulty
Jan 03, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge Freezer
I think you'll find the relay is there to start the pump by switching the mains to the shorter winding in the motor, hence three terminals. Once the pump is running the relay "drops out" and the motor runs on the longer winding. Check with a multimeter if the windings are intact. There's no Positive and Negative for AC operated devices i.e. it doesn't matter which way around the power (live and neutral or Hot and Cold) goes in but Earth or Ground MUST be correct. Dont kill yourself!!
Sep 26, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing (by compressor), Check recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting, YOU CAN TRY turning FREEZER CONTROL To A WARMER FREEZER SETTING Allowing.. MORE AIR.. to refrigertor side
Sep 08, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
