Question about Kyocera Office Equipment & Supplies
Getting an infocode message 007 for paper jam, can't see a paper jam and don't know how to reset
    President:
  • 3,085 Answers
Take out the toner cartidge, Remove and throw away the swinging drum cover, you don't need it . It causes jams if loose.
Posted on Oct 02, 2009
Epson Photo RX510
Hi when you switch it on have you tried holding down the on off button for about 10 seconds as this often resets most printers.
Also when you sya thier is no paper jammed in printer are you absolutely sure their is not even i tiny bit of paper still stuck as it only takes a tiny bit of paper to make this message appear.
If you are confident in removing the paper feed witch is difficult to do as you need to make sure it goes back perfect as if it isnt the paper wont feed.
Alot of people say their is no paper jammedand they call somebody out to repair the printer and they get charged a fortune for removing a tiny bit of paper.
If holding the button down dont work then try switching the plug on whilst holding down the on off button let me know how you get on ok
Dec 10, 2007 | Epson RX620 All-In-One InkJet Photo...
PRINTER IS JAMMED SHOWING ERROR
I had a similar problem, my printer was chewing the paper and then I was getting a jammed paper message. I looked inside but couldn't see much anything. I then removed (unscrewed) all the panels, and next I know, a culprit materialized, in other words, something fell inside the printer. I then managed to put it all back together, ended up with a few extra screws, but heck it works like a clockwork. God bless screwdrivers with magnetic tips, they made my life so easier.
May 23, 2012 | HP Photosmart C6180 All-In-One InkJet...
My fax machine (Samsung SCX4720F) is saying paper jam, there is no paper jam. I have taken out the paper and tryed cleaning the rollers and i'm still getting the error.
The problem is not in the rollers.
If you removed all paper and the paper jam error is still on, then the problem is with the paper sensor itself.
This might be reset by a service code (which I don't know) or the sensor may need replacing.
It is not a cheap machine, so you may want to spend some money servicing it.
May 11, 2011 | Office Equipment & Supplies
I got the error message on my Lexmark C532n 200.26 and 200.16, there is no paper jammed, the Lexmark technician asked me to change the paper pick up roller which we did, but we are still getting the error...
The 200.16 jam indicates that the input sensor was covered when the printer was powered on or reset, or a cover was opened/closed.
You may also check the following:
1. The paper being used is within specification and has been loaded correctly.
2. Any previous jams have been completely removed.
3. The printing environment is within acceptable temperature and humidity ranges.
4. If the tray was overfilled or a paper jam occurred, sheets of paper may have come off the media stack.
5. If you don
Feb 01, 2011 | Lexmark C532n Color Laser Printer
Cleared paper jam but still have message
Mine does the same thing.Try opening all the doors on it and then closing it. For some reason the printer wants to know you have checked all the doors. Also take out the toner drum and check there. If that doesn't work try unplugging it and then plugging it back in. Good luck....hope it helps.
Jul 22, 2009 | Canon imageCLASS MF4370 Black and White...
Network Printer 12 paper jam
In order for a jam message to reset to READY, the printer logic is looking for an "06 COVER OPEN" message. The top cover of the machine must be opened to clear the jam message. If the top cover interlock switch is stuck closed, the printer logic never clears the jam message, even after all the paper has been removed. The printer appears hung with the paper jam message and can only be made READY by powering the printer Off and back On.
Jun 16, 2009 | IBM Network Printer 12 Laser
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Hp 2355 all in one error message
reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
Brother MFC-9420CN Paper Jam B!!!
open and check for paper in the back. sometimes a corner may have been caught in there and will give you the error.
jb
Oct 25, 2007 | Brother MFC-9420CN All-In-One Laser...
256 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
