Question about Gestetner DSc232 Copier
Code 571clearing the code?
We bought a used copier for my wifes menu business. we got it home only to turn it on and see code 571 on the machine? we found out that we should have drained the oil before moving it but to late now!
i removed the service panels and cleaned the machine as best i can but i don't know how to clear the service code? also is there anywere beyond the panels i should look for oil?
  • ckont Oct 02, 2009
    in a laundromat a washer dryer change machine extractor payphone i can trouble shot and fix! i can also fix soda fountians vending machines coolers! copy machines are new to me however
    how do i enter sp mode? how do i clean the eye?
    i need to know how the clear the code
    President:
  • 1,462 Answers
SC 571 is a fusing error caused by not being seated properly or the oil sensor is coated with oil.
More than likely when the machine was move oil coated the senor in the fuser and it has to be taken apart to be cleaned
The error SC51 can be rectified by checking all the possible issues for that..
Error SC 571 :
• Defective oil end sensor
The oil sensor, may be filled with oil, try cleaning the oil from the oil sensor, usually you get this error when moving the object
• Defective oil overflow sensor
There is too much oil in the fuser tank(there should be little oil), remove some oil from the fuser tank
• Defective sensor cable
Check whehter the cable is connected correctly
• Oil level in the fuser is low
Think th level of oil must be low, try filing the oil to recommende level, to start functioning
Please try the above steps and leave me comment, if nothing works..
We may give you some other solution
RNJ VINODKUMAR
you need to enter the service mode to clear the error(service tech only
Posted on Oct 03, 2009
  • 3,741 Answers
Clean the oil in the inner part that is lens assembly and fuser assembly.also clean the oil on heater unit and pressure roller.make it completely oil free.then let it get dried up for some time.then check out. --------------- and also this error occurs if the oil in the oil tank is got empty.so check out. code 571 means Fusing oil end.You have insufficient oil in the oil tank situated at the rear of the machine, please fill up with correct oil.
Afterwards please enter SP mode 5-810 and set to 1, then switch off and on the machine.
If you have sufficient oil in the tank and 571 re-occurs, you have a defective oil pipe, oil pump or oil end sensor.
----------------- thanks.this will help.please do rate the solution.thank you for using fixya.keep updated.
Posted on Oct 02, 2009
Siemens tk68e570/571 it shows "fill up pipe-sys " on the screen
It's not a computer, but a coffee maker. I've had the same problem. In my case it turned out to be the pump that didn't pull in water. I took out the pump(situated below the water tank) and used some lubricant and a compressor to blow through the pump for a couple of minutes and presto, it was back in business!
Feb 11, 2013 | Computers & Internet
1988 KAWASHO TV: Need remote control codes for VERIZON FIOS Remote Control
You may want to try a different universal remote, like the Logitech Harmony.
Apr 07, 2008 | Onkyo TX-SR605 Receiver
Why my acer aspire e1-571 won't shutdown?
i would take it back straight away if you start messing with it they might accuse you of damaging it and decline the warranty on it....
Jan 04, 2013 | Acer Aspire E1-571-6650 Laptop
Ricoh aficio service code sc571
solution found on copytechnet.com
sc571 on this machine means fuser oil overflow.
check the oil out sensor connector.
use sp5 810 to reset this and most other codes.
Apr 02, 2011 | Office Equipment & Supplies
The microsoft office is asking for a 25 character code that I don't have. I downloaded it from the internet for free. How do I get a code for it for free? I mean why not, right!
if downloaded the software fo free...you might wont to be very carefull of this. If there's no key than you could call Microsoft for it at 1-888-571-2048
Feb 22, 2010 | Microsoft Office Home and Student 2007...
SC 571 error
Hello sir; The error code you have display, its means the fuser oil waste bottle full, check it out and dump it out, otherwise that's senser problem.
Feb 02, 2010 | Lanier Office Equipment & Supplies
Wrong code entered. I have an unused one but cant enter it. HELP!
When the trial version license comes close to being expired, notices are supposed to appear and ask for an activation code.This is set to happen automatically at intervals during use, it should not shut down entirely. Look for a message that says Convert and click on that if the powered down version appears.It will guide you through the process. If not, read below.
Go to the Microsoft Office Word program and look for the Microsoft Office button. (See pic).
Click the Microsoft Office button at file menu. In the drop down menu, click Options, down on the very bottom of the menu.
to left is is the activate product option. Highlight that.
Thanks for your post.
Nov 22, 2009 | Microsoft Office Home and Student 2007...
Dsc232 code 571 how to reset
Error code 571 is for oil overflow sensor error.If you pull out fusing unit,on the left side of it there is an oil unit attached,that has oil sensor on it.Most common problem is the sensor is getting disconnected.After you checked the sensor connection,here the procedure to reset the error code:
Turn main power switch off and back on.Then press "clear modes" key, 107 and press and hold "Stop" key for until you see screen has changed. Touch "Copy SP" tab on the screen, the press 5810 and # key. Press "Execute" tab on the screen to reset fusing error code.After that turn the main power to the machine off for a few minutes.Turn the machine back on - the error code should be gone and the machine should be working now.
Oct 05, 2009 | Gestetner DSc232 Copier
Aficio 1224c copier sc 571
More than likely when the machine was move oil coated the senor in the fuser and it has to be taken apart to be cleaned.
Sep 22, 2008 | Office Equipment & Supplies
Problem with copier Rex Rotary DSc232
571 A Fusing oil overflow
• The oil overflow sensor detects oil.
• When the machine covers are
closed, the oil supply unit is not
detected.
closed, the fusing unit is not
detected.
Possible causes :
• Oil supply unit not installed
Jul 08, 2008 | Office Equipment & Supplies
272 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
