I have a Super capacity Plus, Inglis Citation Clothes dryer, Model IES7000,Type 180, Serial no. HH0505421 approx.10 yrs old. Recently it stopped turning itself off, after we had set the timer, and activated the starter switch. We called a technician who billed us & left without solving our problem. He stated that the timer was OK. but he thought that lint had plugged the sensor and caused it to malfunction. This does not make sense to me because a timer should function based on running time. I checked the outlet duct for lint and found that it was clear. I also tried to identify the timer type fitted to the machine based on dryer model number without success. Could you help me identify timer and sensor model number if any ? Does the technician mean a thermostat rather than a sensor?
  • 6 more comments
  • hecosys Oct 06, 2009
    Dear local wonder, I have now pulled out the dryer and discovered I have given you the incorrect model number. The correct model number is IE 87000 , Type 180-00 , Serial MH 0505421 . Volts 115/230, Amps 24, Hz 60. Could you tell me the part number for the sensor and where it is located. My appologies for the incorrect numbers.
    Dear Local Wonder,
    I have located the the "Use and Care Guide" for my Dryer and seven different models are covered by the same booklet. The Model Number closest to mine shown in this booklet is IE 8700. The Model number I have located inside the dryer door is IE 87000. I have inspected the rear of the dryer to locate any model number on the rear panel without success. Is it worth removing the rear panel to determine if the model number is behind the panel ?
  • hecosys Oct 07, 2009
    Normal
    0
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";}
    The only number I can find is shown on a grey label behind
    the door on the rim of the machine is Model IE 87000 together with Type No. 180-00 & Serial No. MH 0505421.
    I have removed the back panel of the dryer and there is a
    number 0569 stamped into edge of the top panel of the machine at the rear.
    I also removed the back of the control panel console & found a part number 3405895.
    Inside the control Console I found a wiring diagram with
    Label No. 3406689 REV. REL
    I have not taken the door apart to look inside it.
    Dear Local Wonder,
    Where is the sensor located? I felt around in the outlet duct & there are two devices installed in the outlet duct upstream of the outlet elbow . One is about 2in long with two terminals the other is a circular disk about 1/2 in in diam.with four terminals .
    I cannot feel or see anything that is 7 in long which is the dimension of the sensor you have recommended.
    It is an electric Unit
    OK Local Wonder,
    What is the part number for the timer?
    Thank you Local Wonder for your help. You stayed with me through all the trials and tribulations.
  • 6,784 Answers
HI. The technician was correct in your case. The sensor and timer work together to insure proper drying time. The timer will continue to run the unit if it receives a resistance signal from the sensor(dryness) that indicates the contents are not dry. If the sensor is covered with lint, it will unbalance the signal, in return, causing the timer to initiate a overrun.
Now, with that being said, you have stated that the sensor was not covered with lint, and the duct was clear. This will confirm that the dryness sensor is damaged, and should be replaced.
I have tried to look up the part numbers to no avail. the actual model number you have posted above, seems to be incomplete. Please try to located the complete model number and post it asap. This will help with the parts search.
Posted on Oct 02, 2009
  • 9 more comments
  • Michael Masters
    Michael Masters Oct 06, 2009
    HI. The model number you have posted is incomplete. The minimum digits for a Inglis unit is nine digits, and the maximum is eleven digit. Please locate the entire model number, if possible. It should be visible on the actual user manual, or unit.
    Without the entire model number, located the parts will be nearly impossible.
  • Michael Masters
    It may be necessary to remove the panel to access the model number in this case, but i would check these other spots as well.
    Look for your model number on the:
    rim, behind the door
    inside of the door
    back panel (towards the top)
  • Michael Masters
    1.bullets rim, behind the door
    2.bullets inside of the door
    3.bullets back (towards the top)
  • Michael Masters
    1. rim, behind the door
    2. inside of the door
    3. back (towards the top)
  • Michael Masters
    Michael Masters Oct 07, 2009
    ok, i will try to search for the model number as well. This will be a blind search, but hopefully i can retrieve the number by using the serial...
  • Michael Masters
    Ok, i have located the actual sensor needed to correct this fault you are experiencing with your unit. Use the link below to be directed to the purchase page.
    CLICK HERE TO PURCHASE YOUR NEW AUTOMATIC DRY SENSOR
  • Michael Masters
    OK, i will try to search for a diagram to help. remember, you have not posted the full and complete model number. I'm merely searching by serial, which is making this search expedition extremely tough. One moment please....
  • Michael Masters
    Is the nature of the unit gas or electric?
  • Michael Masters
    Ok this is good feedback. I can effectively state that the sensors(auto dry sensor), are only attached to the Gas units. The electric units do not have auto sensors. We can rule that out for sure. This will alter my diagnosis slightly. The electric units made by Inglis, are equipped with two thermostats, and a thermal fuse(cut-off). The High limit thermostat is located on the element housing. This device only regulates high element temps. This dose not control the on/off functions at all. The next thermostat will be the Cycling thermo(located on the lint shoot, or blower housing). This device maintains a certain running temp, and regulates the normal range of the element during the selected drying cycle(permanent press,normal,extra dry, etc). And last, There is the Thermal fuse. this is killed by the hi limit thermostat when the element reaches the high limit threshold, which is over 240f. this is a basic safety fuse to prevent over heating , due to a clogged vent or blower housing.
    Ok, this will lead us to the timer, which in my estimation, is the culprit. The timer test is not designed to catch this sort of malfunction. The device will test well, even if this damaged is present.
  • Michael Masters
    Ok, that is the current issue at the moment. we cannot issue the correct part number without the entire model number. There are several timer modules that are listed, but there are , also, several different model numbers as well. each timer module has different specs and voltage rates. The only way to correctly match up the correct timer to your unit, is to relay the entire complete model number of your unit.
    The model number that you have posted is incomplete. Most of the model number are located inside the dryer door on the top rim on a metal plate. it must be 9 to 11 digits long and it cant be the serial. it must be the model number please.
    Without the correct model number, we cant match up the correct timer part number to your unit.
  • Michael Masters
    If you still have trouble locating the model number please call the Parts, Accessories and Attachments Information Center TOLL-FREE at 1-800-807-6777 from 7:30 am to 8:00 pm (EST), Monday to Friday.
Whirlpool admiral clothes dryer won't turn on. It's approx 8-9yrs old & in good condition. The Model number AED4475TQ1 Serial number MY1739210 Type DWJR-ELE-2406026-FM54
Check breaker in breaker box (30 amp). Check door switch plunger on door, check door switch. Check dryer plug in to outlet.
Sep 06, 2015 | Whirlpool Dryers
Clothes are no longer drying on the normal setting. dryer will run for approx 10-15 minutes and shut off. clothers are not dry. have tried other settings and same thing happens.
Try cleaning the metal sensor strips right inside the door opening on the back of the filter housing assembly. You can see them if you put your head in the drum and look down. They are metal, about 4" long or so and about 1/2" apart. Residue builds up on these and over time will not allow them to sense the moisture properly. You can clean them with sandpaper, steel wool, wire brush, or Scotch Brite pad. That will likely remedy your trouble...
Dec 27, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Why does the display say"wet" when the clothes are
Try cleaning your moisture sensing strips with windex. Maybe something wet and sticky is on them
Dec 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool super capacity 465 cracked ceramic element
You are looking at approx. $450.
Jan 01, 2010 | Ovens
KitchenAid Dryer Timer stopped working - won't stop drying
Timers cannot be repaired. The mechanism is a spring - once it weakens, or fails - a new timer is required.
CLICK HERE for your part.
It is $83.72 USD.
Here is a Buy-it-Now eBay auction for $34.99USD & Free shipping!!
CLICK HERE
Your part number for the timer is 3976570a
A used part would have to come from an appliance store that salvaged from an abandoned washer.... and it may fail shortly anyway.
The new timer will have a warranty, and give you 10 more years of service.
Well worth it.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 05, 2009 | KitchenAid KEYS850LQ Electric Dryer
WHIRLPOOL ELECTRIC WASHER STOPPED WORKING MIDWASH BC OF OVERLOAD?
My wife did the same thing,trying to do all the laundry at one time.Even if it says high load compasity it will only handle so much.sounds like you killed your motor.Hope this helped.
For more help go to live chat.
lenwest
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Cabrio Dryer runs for 5-10 Seconds and then the drum stops.
Go to: RepairClinic.com
to troubleshoot your appliance.
You'll need the make & model #.
Nov 16, 2008 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Inglis clothes dryer
The most common cause of this problem is overheating due to airflow restriction caused by lint build up.
There a non resettable thermal fuse in the motor circuit that must be replaced after the the lint blockages are cleaned out..
Mar 22, 2008 | Refrigerators
Washing Machines Logo
154 people viewed this question
Top Washing Machines Experts
