Question about HP LaserJet 1320 Printer
Black line down the left side of document - HP LaserJet 1320 Printer
    Sergeant:
    Champion:
  • 208 Answers
Sounds like a bad tuner cartridge. Try another one and see.
Posted on Oct 02, 2009
    Habit-Forming:
  • 71 Answers
Change toner until is too late for the fuser
  • 46 Answers
SOURCE: line down one side of page.
One of the ink nossels are blocked you can use benzien or hot water to unblock them
Posted on Oct 16, 2009
Bubbabear64
  • 2794 Answers
SOURCE: RICOH AFICIO 1022 ADF scanning with a black line down right-hand side
There is a tiny spec on the scanner glass. Cleaning it will make the line go away.
Posted on Jul 11, 2008
  • 52 Answers
SOURCE: Vertical black line when copy with Koda ESP 3
Some dust particle or something might have been stuck on the scanner. Try cleaning the scanning glass
Posted on May 19, 2009
  • 24 Answers
SOURCE: My HP 1320 prints a thick black line down the left
Easiest step to do would be replace your toner.
Next Step is 1/2 self test page. This means start a print job and after the paper is picked up open the toner cartridge door and cause a jam. The paper that you see after you remove the toner will show the current print. If the mark is seen on the paper there then it is the toner cart. If you dont see it on the paper then it is most likely your fuser causing the issue.
Posted on Jul 27, 2009
xptareq2000
  • 1447 Answers
SOURCE: When using the ADF for scanning to pdf, it creates
Your machine ADF is dirty or dust in adf glass please clean it by soft cloth and scane again its clear and sharp.
thanks.
Posted on Nov 24, 2009
When I scan a document using the feeder on top, the resulting scanned document has two parallel black lines down the left side of the page. What causes it and what fixes it?
When using the ADF if the glass has dirt on it, as the paper moves over the glass the image is written to the moving paper. The paper is also moving over the dirt specs on the glass causing verticle black lines. It is hard to explain without actually showing you. To fix the problem, lift up the top to expose the glass. Look to the left of the big rectangle glass. There will be a 3/4 inch glass strip. CLEAN IT.
Aug 26, 2011 | HP Officejet 6500 Wireless All-in-One...
I get a black line down the left side of the page when a document is printed
Either the black cartridge is bad or the fuser roller is bad. Pull out the black cartridge and gently pull down the flap that runs across the cartridge. Look at the drum inside. If you don't see a line running around the drum or a clump of toner on the drum where the black line appears on the paper, your problem is a bad fuser.
Aug 05, 2011 | HP Laserjet Cp2025n Printer
Got a dark line down document when scanner via AFD
When you use the adf, the scanner remains stationary at the far left side of the platen. Check and make sure that the glass is very clean there; use a damp cloth to remove any dirt or other foreign material.
May 27, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
When using the ADF for scanning to pdf, it creates black lines vertically down the left side of the document. If I use the flatbed scanner, no lines.
thanks.
Nov 24, 2009 | Brother MFC-7820N Printer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Black streak down side when making a copy
Hello sir; I believe you need to replace drum cleaning blade.
Mar 12, 2009 | HP Office Equipment & Supplies
Black line down my faxes
Open up the document feeder and clean the scanner glass. Look straight down at the bottom inside of the door
Jan 30, 2009 | HP J4680 Office Jet All-In-One Printer
HP LaserJet 1320 Printer Logo
220 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
