Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Was mowing the lawn and the blades stopped rotating and won't engage.
  • 855 Answers
Check that the belt didn't break. If the belt is fine check the pto it may not engage the blabes. Some pto's are electric some manual. Depending on what you have to do to engage the blades. That will tell you where to check.
Posted on Oct 02, 2009
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Tractor quits when engaging the blades
unhook clutch and see if blades stop turnig and then try engage clutch with the switch if motor stays running bad clutch
Jun 01, 2013 | Mtd Garden
Managemylife com
check that the cable isnt unhooked
May 01, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Disengaging blades when mowing completed
the cam plate that the tensioner pulley is mounted on that rotates back around to tighten the belt as the cable or rod is engaged is likely rusted and worn, there is a bushing in this pivot that can be removed and cleaned fairly easily with a abrasive wheel or pad and lubricated upon reassembly.
Jul 04, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Jun 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Blades not engaging
Tim, first turn key on engage and disengage blade button. See if you can hear the clutch making a clicking noise. If not check switch., if not your problem is in the clutch.
May 29, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
755 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
