Teac x10r tape recorder
Just got a teac x10r and not sure if its working....the pinch rollers wont move up to the tape....is there a manuel on line for this
  • Anonymous Mar 17, 2008
    how can i change the belt?where can i get a new one?
  • Anonymous Apr 26, 2008
    Pinch rollers will not engage.
If the tape transport doesn't move up on play, but you can push it up and pull it down by hand, the grease on pivots is all dried up. you can take it apart and clean it. replace belt while your at it.
Posted on Dec 31, 2007
Even if you change the belts be sure to clean the pivot points with 95% isopropol alcohol or buy a smal airplane botle of everclear grain alcohol from the abc, store trust me it is alot easier to find than the iso. alcohol.Then relube with white grease and test,alot of times the belts burn -stretch due to too much resistance at the pivot points from grease that has hardened.And always clean the heads and tape path with the same alcohol.do not use alcohol on the pinch rolers or any other ruber parts it wil mes them up,you can buy specialty cleaner for these,I just use a mild soap detergent and warm water and dry completely before reinstaling.
Posted on May 24, 2010
I have a deck with the same problem. I opened up the deck and found that both of the belts had disintegrated into black, gooey mush.
You should check the belts. They may the source of your problem.
Posted on Oct 12, 2009
  • Audio Player... Master
  • 1,267 Answers
Belts are certainly in need of inspection and if soft or loose then change them. Belts of the right size are getting harder to find all the time. That is why I am ordering items from Marrs Communications and just put those in. More costly than the other way but if you get the wrong belt in there the system will not work correctly. No need to buy any special solution for rubber cleaning- I have used Denatured alcohol from a paint or hardware store for more that 40 years and no pinch roller has ever cracked or decayed from it, Soap and water will keep you scrubbing for hours- I don't have that time to waste as too many units here for repair. I have had NO trouble from the alcohol that I use from Sunnyside called denatured alcohol. We also used the same thing at Teac and Sony Factory Service centers. The rubber cleaner can be used on rubber to recondition it if a path is in the rubber- that was called RC-1 or 2 but it has been learned that the chemical was made for Teac by Rawn company in Wisconsin and that it's composition was mostly Naphtha- which again is available at paint or hardware store. I am currently using those very products in my repair business 6 days a week.
Skywave Tape Deck Repair,
Posted on Jan 18, 2013
How can I be sure I am getting a 16.8 belt for my TEAC x10r R2R? I don't want a 17. Thanks!
You can order them from Marrs Communication. That is where I get mine and I am a past Teac Lead Technician. The 16.8" X .330" ones are the best ones. Don't buy a 17" belt from Teac as this is the wrong size. Many of my clients find this out as I have to change them inside of 6 months.
Sep 27, 2016 | Teac Audio Players & Recorders
Teac x-1000r tape skewing off pinch roller
In the Teac X1000R this is most often caused by dirty Pinch Rollers and secondly bu a ring of oxide or a wear mark being developed into the capstan shaft. If cleaning the Pinch Rollers does not do it then a trip to the technician is required. These decks also have a touchy servo tension system that if upset can also contribute to the failure of this kind. I still work on these in Chicago area all the time. Russ the other ex-Teac guy is in New Jersey. Be careful of local shop with this model as many of them turn up the servo tension to resolve this problem which is the wrong thing to do that then burns out parts and the cost goes up. I have seen this mess many times as people bring me these decks as a last stop-- of course I fix then correctly with the use of the Tentelometer as is required. Pinch Rollers are often reconditioned with Naphtha after cleaning then with Denatured alcohol.
Teac Tascam Repairs Skywave Tape Deck Repair Bensenville IL
Mar 14, 2014 | Audio Players & Recorders
My Teac W450R works except the RH side RPM speed ti too slow. Does it need lube or cleaned? All functions work well otherwise.
It may need a calibration with a speed tape and frequency counter or wow and flutter meter. You should make sure the Pinch Roller is clean too.
Mar 06, 2014 | Teac Audio Players & Recorders
My reel to reel will not play.
You need a new capstan belt or the capstan shaft is glazed as well as you have a hard shiny Pinch Roller. Each of these items need to have friction to work.
Nov 19, 2013 | Teac Audio Players & Recorders
How 2 change belt and grease pinch roller on teac x10r
The belt which should be a 16.8" can be replaced by taking off the thrust plate from the rear of the deck and taking out thye flywheel one at a time and oiling the bearing. Clean the belt area of the flywheels with alcohol and apply the new belt. The belt will need to be lifted up over the motor pulley so that the pulley is on the bottom. The Pinch Roller linkage is addressed from the front taking off the eschuteon that sits under the head cover. Clean the links with alcohol getting all old grease off then apply Lubriplate not oil. Make sure the item are assembled correctly- there are washers and a stud to go into a link place under the assembly- I have done 100 of them by now.
Oct 31, 2013 | Audio Players & Recorders
Thaks for helping. My tape deck door has suddenly stopped working. the tape is inside and when i turn on the wpower there is a clicking sound. it is a TEAC AD-500 CD player/reverse cassete deck
Without physically looking at the cassette deck myself, I cannot be 100% sure the tape is wrapped around the pinch roller and capstan. The capstan is the chrome rod which the rubber pinch roller pushes to regulate the speed of the tape moving across the head. However it is approximately a 90% chance the take up reel for the tape stopped working from a bad tape or a loose belt which drives the tape take up reel. The clicking sounds like it could be the auto reverse solenoid because it thinks the tape has reached the end of play. The fun part is to remove the tape which you may have to disassemble the front panel if you cannot gain access to the tape from the top or bottom. You will need to cut the tape and remove it from the capstan and pinch roller to open the cassette door. Sometimes you can remove the capstan to free the tape. Once you have cleaned all the tape out of the unit make sure the belt for the take-up is good. If it is glazed, cracked, loose or broken order a belt. Clean all the pulleys and capstan and replace the belt. Your unit should be functional after the above procedure.
Jul 14, 2011 | Teac R-H300 Dual Cassette Deck
My Teac 4070G reel to reel tape deck rewind and fast forward functions work, but the play function does not. Any ideas? Could it be a circuit?
Without actually seeing your Teac reel deck, i suggest you verify that all fuzes in the deck are good..not blown. Also with a tape correctly installed..ensure that left and right tape tension arms are held under tension/ closed by tape tension, also ensure the capstan shaft is rotating... look in back to ensure the capstan drive motor is running.. if yes, and tape still will not play... problem could be a stuck/failed solenoid, dirty or corroded push buttons, or corrosion on contacts where rear circuit boards/plugs insert into other boards.
Feb 28, 2010 | Audio Players & Recorders
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
890 people viewed this question
 Grubhead
Grubhead
