Question about Philips 60PP9352 60" Rear Projection Television
My phillips projection tv model 60pp93 5217 has power going to it but will not turn on
  • noley_baker May 11, 2010
    Is the LED on the front panel blinking?
    Champion:
  • 230 Answers
Hi, thank you for visit fixya.
This kind tv is a trouble set.
3 possilbes solutions:
1.- SSB ( small signal board)
2.- Fly back ( high volts transformer)
3.- Convergence STK IC's ( stk 392-110).
I recommeded visit a near tv shop and request a estimate repair tv.
I am sorry if Am no clear about your tv solution, but, Honestly; Philips TV is a little hard for repair.
Any question I will be here. Thank you
Posted on Dec 05, 2009
I have a sony LCD projection TV Model # KF-50XBR800 and when I go and turn it on my standby button flashes red and then picture comes on for about 10 seconds then it shuts itself off. Can you tell me what...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Aug 28, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
Phillips Magnovox
Its a power supply issue the only solution is to get it repaired.Possible power outage.Repair charges would be around $400.
Goodluck,
Please don't forget to rate the solution
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
Hitachi projection tv will only turn on periodically. I power the tv up and sometimes it turns right on and other times it seems to power up but then front 3 lights on the front start blinking and the tv...
I don't know what model you have but ... the 50v715 I have did the same thing. Would come up for about 3 to 30 sec's (picture and sound) then shut down and do again. It was the BULB going out. You probably just need to replace your bulb. Check your manual on how to change it out. Make sure you buy an original Hitachi replacement I think there made by phillips. Hope this is helpful.
Oct 26, 2009 | Hitachi Televison & Video
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
No sign of power on my Phillips Magnavox rear projection TV
try replacing the fuse. it should be behind the bottom panel near the power cord
Nov 17, 2008 | Televison & Video
Power Problem (Phillips 55P8341 Projection TV)
Same problem... I pulled out the second electronic board going from right to left and see a burned diode at position 3307. I wanted to know if anyone has a schematic of this TV and could tell me the numeric value of the part in position 3307. It would be appreciated it you could let me know.Thanks...
May 30, 2008 | Philips 55P8341 55" Rear Projection...
Blinking Power Light 9 Times Phillips 60PP920299
go to this link they may have your service manual for your tv they list them by chassis numbers so if you don't see it leave them an e-mail with your model number and they are very good about getting back with you
http://servicemanuals.vstore.ca/
May 09, 2008 | Philips 60PP9202 60" Rear Projection...
Help..... Phillip Magnovox Model 9P5034X101
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
424 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
