Question about Husqvarna Forest & Garden 125bt Backpack Blower
HAVE SPARK STILL NO START SPRAYED IN CARB CLEAN STILL NO START
  • 1,040 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
  • Jim Parker
    Jim Parker Nov 30, 2009
    Did this solve the problem?
    Jim
Polaris 2013 50 outlaw will not start or idle have cleaned gas tank, carburetor check all fuel lines spark plug what is wrong
did you remove the carb and clean in a vat and rebuild it or just sprayed a can of carb cleaner thru it. needs toom part and cleand and rebuilt... this is a comman issue with those models
Jul 27, 2014 | Polaris 2013 Outlaw 50
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Weedeater PE550 will not stay on. Prior to placing this unit in long-term storage, the unit worked. Since pulling it out for this season, it would not start. I replaced the fuel lines and primer bulb. ...
Is the smoke coming from the spark plug hole or just near it?
There are three things that you need for it to work.
Fuel, air and spark.
If you are missing any one of those things, or if one isn't optimal, it wont work well if at all.
You say spraying carb cleaner into the chamber lets it start, but after a minute it dies?
That tells me you are getting a spark.
Have you taken the carburetor out and cleaned it thoroughly with carb cleaner?
Often when fuel sits around inside a carburetor it can build up gunk and make it not function properly. I recommend removing the carburetor and taking it completely apart, cleaning everything with carb cleaner and putting it back together. It sounds difficult, but I promise it is not, just take pictures to help you remember how everything goes together if you want.
Also while you are at it either clean or replace the the air filter, that should help as well. If its a foam filter you can clean it with gas, if its paper, just buy a new one.
Jun 07, 2011 | Poulan Pe550 Gas Edger
2008 mtd lawnmower tries to start when sprayed with carb cleaner but stops after 3 seconds
If the spark plug is in great condition, remove and clean the carburetor. This will require soaking if needed with a good solvent or carb cleaner and compressed air to blow out the tiny passages that are clogged for the idle jet circuit and high speed circuit.
Apr 29, 2011 | Mtd 22" Yard Machine Push Mower
Will not start
If you have a spark plug wrench take out the spark plug look at it if it is all wet engine is flooded with gas,dry it and clean it if it is dry its not getting gas, try putting in a new spark plug. is there gas in tank , is switch on, is gas turned off, is the tank full, is the gas old and stinky? has the tiller sat for months carb may be plugged check ,engine oil level, try a little shot of engine starting fluid or gas sprayed into carb needle valve in carb may be pluged, float in carb may be stuck. tap on carburetor good luck
Jan 31, 2011 | Troy-Bilt Garden
Will not start
you dont need a manual. you need competent troubleshooting knowledge.
do you have an ignition spark? if you do then it will fire up on WD40 or StartingFluid sprayed in the opened carb. if it does and you have a clean fuel supply flow. clean the carb paths.
If no ignition spark present, check wiring, meter the coil for possible open circuit,
Mar 11, 2009 | Garden
Bike will not start
I would take the carb off and clean the jets. I had a bike that if i didnt ad stabil to it, the gas would varnish in just about a month. It also depends on what kind of gas you put in there and if you fill the tank up so condensation doesnt get in there.
Jan 08, 2009 | 2000 Suzuki LS 650 Savage
Husqvarna Forest & Garden 125bt Backpack Blower Logo
212 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
