Question about Garden
What size spark plug does a 120 use and what size socket do you use to take it out
MrRodneyLong
  • 55 Answers
SOURCE: 1997 escort 1.8 gti zetec
it should be a 5/8th inch (us) assuming that this is a AGSP32C plug that cross ref to a 2756 NGK plug. Let me know MRRodneyLong@gmail.com
Posted on Jul 03, 2008
SOURCE: what size spark plug socket do i need?
1996 gsx600f what size spark plug socket do i need
Posted on Jan 30, 2010
SOURCE: 2008 dodge avenger spark plug location and socket size.
  • 2008+ Dodge Avenger 2.4L 4cyl.
  • Remove plastic cover on top of engine, just pull on each corner for it is friction fit.
  • Once removed you will see 4 black spark plug covers with one hex type screw holding each.
  • Remove Hex screw and place aside, pull upward to remove plug boot from plug.
  • To remove the plug, use a 5/8 socket with a 6" extension. Once plug has been turned out all the way and you cannot get the plug up and out of the hole, just press the plug boot back on the plug and pull it back up.
  • Gap and replace 4 plugs with the same or equavalent type,. Drop plug down the hole and use socket to align and tighten until just snug, then torque to manufactures specifications.
Posted on Feb 23, 2010
SOURCE: Changing Spark Plugs on 1999 Honda Shadow 750
Yes, it is an 18mm plug but you will need to use the Honda Plug Tool which is part of the stock tool kit just below the seat. Use that and you will get all of the plugs out very easily.
Posted on Jan 17, 2011
oneStan
  • 430 Answers
SOURCE: Peugeot 207 spark plug size
8 mm according to my Pugeot and Mercedes reference.
I would have a complete set of 3/8" Metrics 12 pt sockets on hand to be sure at the time of doing the job as sometimes our manuals are not exact due to the many variables.
It shows a thin walled 12 point metric. I know my BMW uses a 10MM thin walled for the irridium plugs.
You can find the tool mentioned on eBay, it has a special clip to retain the plug as you extract & insert it.
Mercedes M156 engine, Peugeot 207 and 307, Renault 1.2 16v SPARK PLUG SOCKET 8MM Item #120884075060.
Posted on Mar 28, 2012
2001 Chevy cavalier It's a 2.2 litre 4 cylinder. what size of spark plug socket do I need to replace my spark plugs ? Please advise !!
When you buy the new spark plugs, take one of the plugs and get a spark plug socket to fit. The size may depend on the brand? Try 5/8 spark plug socket. Hopefully the socket for the new plugs will fit the old plugs?
May 14, 2015 | Cars & Trucks
What size torque driver do ineed to change spark plugs 2007 jeep compass
im guess this is a socket size? question?
open hood look up see spark plugs used.
now you have them in hand right? buy them at the counter
and then grab a socket that fits?
or if no in a store. you say plan to buy ngk plugs
you go online look at, NGK.com and the spark catalog
look up your plug, and see the spec page there and behole
all NGK sparks are list for socket size there.
i do that, see V-tech plugs.
ZFR5F-11 #
i goggle that (lazy) and get hex size
it shows.
2nd hit
see spec tab . click that
http://www.ngk.com/product.aspx?zpid=10210
Aug 08, 2014 | 2007 Jeep Compass 2.4
Spark plug socket size
Should be a 5/8 in spark plug socket.
Jan 30, 2013 | 2005 Buick LeSabre
1975 Honda CB 400 F Spark plug info
Hi, your plug number for an NGK plug is D8ESL As far as the plug socket size it is a 13/16 deep well socket. The gap should be set at .07-.08mm.
Aug 23, 2009 | 1975 Honda Cb 400 F
How to change the spark plugs
if its your first time you need a haynes repair manual.you need a spark plug boot puller.you need 3/8 ratchet wrench.spark plug sockets.from size 5/8 to 13/16.you probably need size 5/8 socket.you need extensions different sizes.and universal joints.to reach hard to get plugs.you need torque wrench. and spark plug gap set.
Jul 07, 2009 | 2002 Kia Sportage
What size socket do I need for the spark plugs on a 1992 honda accord EX?
The standard size of 5/8 spark plug socket with a 1/2 drive.
Jul 07, 2009 | 1992 Honda Accord
How to change spark plugs... 2003 ES300
Hi!
You need New Spark Plugs, Spark Plug Wrench Socket and Wrench Extension (at least 2-3 inch) size 10 socket and/or size 12 socket.
First of all, please check where the spark plug cover is. Once you figure that out there will probably be size 10 or/and 12 bolts holding it down. Take that off and there you will see sensors connecting to each other and holding the spark plug in the cylinders. Unplug all the sensors and pull out the circular plugs holding the spark plugs down. Pull them out and make sure that you don't drop anything into the cylinderes. You can look down into them and see the spark plugs. Get your spark plug wrench, extension, and socket wrench and stick them down in and push so that the spark plug wrench grabs them. Then unscrew the plugs, pull them out and put the next ones in and tighten them down. Just connect all the sensors, and put the cover back on.
Thanks for using FixYa and do rate if found this solution helpful.
Thanks
Rylee
Mar 27, 2009 | 2003 Lexus ES 300
How do i reach the rear spark plugs on the 24v 3.0L 1999 Mercury Sable
I recently did a tuneup on my 88 sable, and the back spark plugs were a pain to get to. However, it didn't require any special procedures. You may want to try getting a SMALL ratchet extension to avoid jamming your wrench into the firewall, because without one you won't be able to get far enough into the spark plug seat and a normal sized extension will prevent you from getting in at all. You could also try an appropriately sized deep socket (sorry I can't remember what size the plugs are) and use that instead of a spark plug socket. Just try to use the spark plug socket to put the new ones in, or you may damage the connectors using a normal socket.
Jun 19, 2008 | 1998 Mercury Sable
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
