Question about Kenmore 98702 Stacked Washer/Dryer
How do you light piolot light on model 417.94872302
    President:
  • 1,304 Answers
There is no piolet in thisa model
if your not getting ignition its the ignitor
part number
134192000
Posted on Oct 03, 2009
How do u light a white westinghouse oven manual with out piolot light?
There is no way the oven will work if their is no power to it or if thier is power it will not work unless the electronic ingiter first comes on..the surface burners could be lit w/ a match however
Aug 26, 2011 | Ovens
Cant figure out how to relite my furnace
on the bottom of the unit there is an access door remove it and behind it you will find a gas valve and a pilot find the piolot......turn off the gas valve and move the selector to piolot depress the switch and at the same time place the flame from a log lighter onto the pilot light after this lights turn the gas valve to run and the burner should light.
Mar 03, 2011 | Empire Direct Vent Wall Furnace;...
Burner and piolot light keeps going out
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Jan 04, 2011 | Heating & Cooling
Piolot light wont stay light.
Here's a solution that'll blow your socks off!
Get the thing running.
Then briskly tap the pilot supply line.
Watch as the line cleanses itself.
Should be fine for a long time.
Dec 14, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
When one of the gas hobs is on ,it does not burn with a blue flame but a more yellow one .also black soot forms under the burner plate.it is on lpg
Have to adjust the piolot lights for the amount of gas coming out. U have too much gas coming out(yellow flame). On older gas ranges, there was a small screw between the piolot light & burners that had to be adjusted. (if this is a older model) have to turn the screw just a little at a time, till ur flame returns to blue on ur burners. Hope this helps.
Sep 12, 2010 | Microwave Ovens
How to reignite the pilot
most modern dryers have a ignitor.if your dryer has a piolot open the excess door, you should see a red lever,pull it back the light the bar that runs along the side of the burner to the piolot.you have to hold the lever back for two mnts before you can release it. if it does not stay lit you should call for service after shutting off your gas to the dryer.
Mar 06, 2010 | Maytag Dryers
Model SRPH02 BURNER WILL NOT FIRE
Bad flame sensor. Try to clean it with some steel wool
Apr 24, 2009 | Williams 2509612 Ceramic Mid-Size Heater
My ventless gas heater has an uneven flame with orange tips, the flame toward the outer edge is higher than the flame in the middle, and also,when I light the heater, it doesn't just give me a piolot...
This sounds like your gas valve is weak. An orange flame has to much gas and not enough air mixture. Have you trie to ajust the air mixture. If it won't ajust then you will need to replace the valve.
I hope this helps.
Oct 24, 2008 | Heating & Cooling
Kenmore 98702 Stacked Washer/Dryer Logo
Sal DeAngelo
fordexpert
Ed Mac
