Question about Samsung S8300 Ultra Touch platinium-red Cell Phone
On the touch screen how do i turn off the sound so that when i touch the menus there is no sound
    Problem Solver:
  • 5 Answers
Use the volume up/down button while u r on normal profile. press down down down and again down and that's all :)
Posted on Nov 26, 2009
Cm6040 unlock menu
Navigate the Administration menu
From the Home screen, touch Administration to open the menu structure. You might need to scroll to
the bottom of the Home screen to see this feature.
The Administration menu has several sub-menus, which are listed on the left side of the screen. Touch
the name of a menu to expand the structure. A plus sign (+) next to a menu name means that it contains
sub-menus. Continue opening the structure until you reach the option that you want to configure. To
return to the previous level, touch Back.
To exit the Administration menu, touch the Home button in the upper-left corner of the screen.
The device has built-in Help that explains each of the features that are available through the menus.
Help is available for many menus on the right-hand side of the touchscreen. Or, to open the global Help
system, touch the Help button in the upper-right corner of the screen.
The tables in the sections that follow indicate the overall structure of each menu under the Administration
menu
Aug 13, 2014 | HP Color LaserJet CM6040f MFP Q3939A...
I want to put a password at my lexmark printer could that be done.
The User guide has all the information you need to perform thsi action.
Setting Password Protect for the menus
Apply an administrative password to restrict unauthorized users from making changes to the MFP configuration from either the control panel or the Embedded Web Server (EWS).
1 Touch the Menus button on the home screen.
2 Touch Settings.
3 Touch the down arrow and then touch Security.
4 Touch the down arrow and then touch Create/Change Passwords --> Create/Change Advanced Password.
5 Enter and reenter a password of both alphabetic and non-alphabetic characters. The password must be a minimum of 8 characters.
6 Touch Submit.
7 Touch Settings --> Security --> Password Protect to view what configuration settings are protected by the
Advanced Password.
Note: Settings --> Security --> Password Protect and Settings --> Security --> Create/Change Passwords --> Create Change user Password can be used to restrict access with a different password than the Advanced Password. Use Settings --> Security --> Password Protect to select the menus that are accessible with both an Advanced Password and a User Password.
Note: The Advanced Password and the User Password protect the menus on the touch screen control panel of the MFP and the Configuration section of the EWS pages.
Restricting Function Access
The MFP supports a variety of methods for authenticating users prior to allowing access to functions.
1 Open a Web browser. In the address line, enter the IP address of the MFP being configured using this format:
http://ip_address/.
2 Click Configuration.
3 Under Other Settings, click Security.
d Select an authentication method.
e Click Submit.
4 Click on the setup link for the authentication method previously selected in step d.
a Fill out the appropriate information for the environment.
b Click Submit.
5 Click Function Access.
a Set the function authentication level for each function. Select Off to prevent anyone from using a function.
b Click Submit.
Preventing access to the menus from the control panel
It is possible to prevent access to all the menus using the control panel touch screen. To prevent access:
2 Touch Settings.
3 Touch the down arrow.
4 Touch Security --> Function Access --> Menus --> Disabled.
5 Touch Submit.
Apr 16, 2013 | Lexmarkr X646E Multifunction Printer -...
Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
Nov 24, 2010 | Husqvarna Designer I
My Designer 1 touch screen is not responding. I know how to calibrate it, but can't do even that until I can select the options on the screen. Is there a way to unlock it?
I have this information from a person who was a Husqvarna Designer expert:
When you just can't get to the menus at all:
Turn the machine off.
Then hold down the "Reverse" and "Pivot" buttons and power it back on.
You now have the setup screen.
Touch the "Needle Down" button and you will see the crosses.
Use a small blunt object like the metal end of the buttonhole foot (the stylus that
came with the machine would be better ) and
touch the centre of the crosses and each will turn green. Then click on
"save".
Oct 11, 2010 | Husqvarna Designer I
Lg voyager touch screen bounces from one menu to another
The latest version of the firmware solved a couple touch screen issues. (v11) take it into version to get it checked out.
Jan 12, 2009 | LG VOYAGER VX10000 Cellular Phone
Swicthed on tv and its a blank screen..now it wont switch off.
Can you see the menus on the screen?
Can you hear audio (sound)?
If you can hear sound but no menu we need to check the backlight.
Take a flashlight and shine it on the screen, look very closely at the screen.
Do you see a video image?
Let me know what happens, I can assist further.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 09, 2009 | Samsung Televison & Video
Set up e-mail address in Canon 5020i
1) press the * (star) button with the head shape around it
2) on the screen touch on "Address book Settings"
3) Touch on "register address"
4) Touch on "E-mail"
5) in the bottom left hand corner of the screen touch on "Register New Address"
6) Touch on "e-mail"
7) Touch on "name" and enter the recipients name and press "OK"
8)Touch on "e-mail address" and enter the recipients e-mail address and press "ok"
9) Touch on "ok" again
Repeat steps 6 - 9 to add additional addresses otherwise touch on "done" 4 times to exit the menus
If you wish to register the e-mail addresses in the one-touch address book, follow the steps below:
3) touch on "one touch buttons"
4) touch on an empty block
5) touch on "register/edit"
6) touch on "e-mail"
7) touch on "name" and enter the person's name and press "ok"
8) touch on "one touch button name" and enter the person's name again (here you're restricted to 12 characters so you may need to abbreviate it somehow) and press on "ok"
9) touch on "e-mail address" and enter the e-mail address and press "ok"
10) touch on "ok"
repeat steps 4 - 10 to add more addresses. or touch on "done" 4 times to exit the menus.
May 09, 2008 | Office Equipment & Supplies
Onl-screen wording
turn off captioning. Look through the menus. May need to use the original remote.
Oct 29, 2007 | Televison & Video
Samsung S8300 Ultra Touch platinium-red Cell Phone Logo
199 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
