Question about Philips Radio Communications
Philips VOX130 Wireless Headset - on/off button doesn't work
The on/off button no longer works! It no longer clicks on.
It's broken and not worth repairing ...
Posted on Oct 05, 2009
Red button doesn't show on Philips TV after digital switchover
What is the exact model number to your Philips TV?
Apr 21, 2012 | Televison & Video
My ipod is just playing without the sound carrying through to the speakers. I dont know how to make it work?
Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
Original iPhone only: While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port:
To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
If restarting the iPhone doesn't resolve the issue, try restoring the device.
May 28, 2011 | Audio Players & Recorders
Savi Office WO100 won't charge. The green light on the base is blinking but my computer says there is 0% percent charge.
There are two possible solutions to this issue:
1. The headset needs to be reset.
2. The headset is defective and should be replaced.
To reset the headset, use a straightened paperclip to push the reset button on the inside of the headset, below the earhook. See the pic:
You may need to hold the reset button for a few seconds. Then replace the headset into the cradle. You should see normal behavior again.
If this doesn't work. you will need to replace the headset.
Apr 07, 2011 | Plantronics Savi Office Wireless Cordless...
Motorolla headset h700 pair with blackbery
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open the headset and pressand hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
If this doesnt work: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Jun 06, 2009 | Motorola Mobility H700 Wireless Headset
The Headset will no longer activate the handset lifter module
A few things you can do: 1. Make sure that the lifter isn't lifting the phone too high.  To change this, look at the back of the lifter, there is a switch that goes from low to high.  Make sure that's at the lowest setting.
2. Try a reset.  To re-set this unit hold down the minus button on the headset and the call answer button at the same time.  Hold them both until you see the orange light by the call answer button flash a few times.  It should then go off.  If it doesn't go off after 10 seconds release both buttons and push the minus button once more.  The light should now be off.  Put the headset back in the cradle and try again, it should work now.
Mar 19, 2009 | Plantronics CS70 Wireless Headset
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Pin number for philips SHB6100 aside from 0000.
yeah hedenram is right. my problem was that i was trying to pair something WITHOUT the headset in pairing mode. just switching it on doesnt put the headset in pairing mode and it will reject the 0000 passkey even if this is correct. it is vital when you turn on you hold the power button til it flashes red/green and then it will be in pairing mode and accept the 0000. the only way i found this was in the instruction booklet which i thought i had chucked away
Oct 22, 2008 | Philips VOX120 Wireless Headset
Vox130/17
turn on the bluetooth by pressing the phone button on it but dont release the button.After it turns on hold it for another few seconds. the light alternate green and amber. This means device is in pairing mode. So turn on your phoe bluetooth and search this new device.. that easy..
Aug 05, 2008 | Philips BLUETOOTH? LAPEL STYLE EARBUD...
Connection problem for Philips VOX130 with other bluetooth devices
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select VOX130 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jul 05, 2008 | Philips VOX130 Wireless Headset
Radio Communications Logo
202 people viewed this question
Top Philips Radio Communications Experts
Computer Repairing
Computer Repairing
wwlvictoria
wwlvictoria
kiranbodapothula
Are you a Philips Radio Communication Expert? Answer questions, earn points and help others
