Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
No power no light
Try to turn on power but doesnt do anything. not even a light. could this be a motherboard problem or power supply?
  • 1 more comment
  • nimsnuts Jan 02, 2008
    I was having the same problem, I bought and installed a new power supply, and a new HD (the nerd at comp usa supposedly checked the drive to see if it was good and told me I needed a new one) but the computer wouldn't boot. I was thinking maybe the motherboard was bad. I read the solution posted here and did the test on the power supply and the old one was good, then I tried the toggle switch thing and it started right up. Thanks so much for saving me time and money.
  • David Cruz
    David Cruz Jan 04, 2008
    Thanks everyone for all your help.
  • David Cruz
    Thank you for your help.
    Sergeant:
  • 239 Answers
Hello I just wanted to let you know I have had the same problem and Had to replace the mother board. The computer has been working fine ever since look inside your computer and see if you see a green light on inside on the mother board you should be able to see it on by looking thru the back vents, Check it out, Also so when you plug in the power cord do you hear the fan turn on for a second or two. If not, and you see the green light on the mother board, I would say its the mother board I would also suggest replacing the power supply, Dell will recommend that and I do to. Its about 139.00 dollars for both from Dell. Hope that gets you up and going . bear001
Posted on Jan 04, 2008
    Scholar:
  • 103 Answers
Could be either one, or it could be the toggle switch.
Start with the easiest first to check. Unplug the power toggle switch from the mainboard and take a screwdriver or something and short out those two pins to see if it starts the pc. if it does, then your pc case switch is just bad.
If that's not the problem, check the power supply next.
Jumper the ATX 20 pin power cable's green wire to any black, just to make sure the power supply is working. The fans in the power supply will turn on along with anything else hooked up.
To jumper the power supply use a section of wire or a bread twisty (with the insulation removed from the ends) and just connect the green wire to any black wire on the 20 / 24 pin power connector. Make sure that the power switch on the back of the power supply is switched on.
If neither of those seem to be the problem, then most likely it is the motherboard or the processor.
Posted on Dec 21, 2007
Gateway mt6919 does not turn on shows red light
If its doing it while its plugged into the power supply, either the power supply has gone bad, the battery is completely dead (many laptops need a battery inserted that works even if it is plugged in), or the motherboard has failed.
A new battery ranges from $30-90, power supplies go from $10-150 and motherboards could be very expensive to replace, in many cases it would cost more than the laptop is worth if its 3+ years old. A light of some kind should come on when you plug the power supply in to the laptop, even if you havent tried to turn it on. That is the best indicator that it is working. You can test the power supply by using a volt meter, put the probe on the outside ring and another probe on the inside pin. You can switch in case the polarity is reversed and doesnt register anything on the volt meter.
If this is an older laptop that you've had for a long time, it might be a good time to think about just getting a new one, there are some very inexpensive options out there, you can get the data off your old laptop by pulling the drive out and connecting it with a IDE or SATA drive adaptor (also very inexpensive).
Jan 09, 2014 | Computers & Internet
There was no beeep sound heard at the beginning Delay in turn fan power supply the Power LED on the front panel of the computer doesnt light the HDD LED on the front panel of the computer doesn't...
as i always say:
intercept all of cables of your PC case and even power cable of your monitor.
evolve battery of bios then wait for 25 minutes then connect all of cables and try turning on your PC:
1- with battery of bios
2- without battery of bios
it should work.
(this works cause the motherboard reset it's bios and start correctly again).
Jan 13, 2011 | Biostar TF7100P-M7 Motherboard
I have an rdx 200 motherboard brand new but I cant load anything not even bios 4 diagnositc lights show up.
try a new power supply first. There is a light on the board that comes on when the power supply is plugged in.
May 20, 2010 | DFI LANParty UT RDX200 CF-DR Motherboard
MB green light on but won't start
your power supply must be exact and both power connections to the motherboard must be connected. the green light will come on if voltage is supplied but will turn on a low voltage alarm which is a buzzing sound. or it just wont do anything
Jan 25, 2010 | E-Machines T3624 PC Desktop
Emachine t5026 does not appear to have any power, when you unplug the power cable from unit the ehaust fans breifly turn on, and light on mother board flickers, other than that sign of power Tried putting...
Unplug every thing such as the CD/DVD trays, Hard Drive, take out any dial-up modems, network cards, video cards, etc. unplug even the mouse and keyboard. Try powering on agan. If the computer seems to work, then power back off and plug in one device then power on computer. Keep doing that until you find the bad device preventing the computer from turning on.
If that doesnt work then carefully remove the RAM completely then carefully replace the RAM. Now with on the Dynex power supply plugged in to the motherboard, try again. If still nothing, remove the RAM and try again. If it still does the same thing, then the motherboard is dead and needs replaced. If instead you get a series of beeps then the problem MAY be bad RAM. Try different RAM. If that doesnt help. The only thing left is taking out the CMOS battery, It is the coin shaped battery on the motherboard. Take it out and wait 20 seconds then put it back. I doubt it is the CMOS battery, but at this point it is worth a shot.
Nov 13, 2009 | E-Machines T5026 PC Desktop
7720 Travelmate turned off and startet again only once
Try without battery.
If it set the problem, let me know
Check power supply if green led lights up
if not try other power supply if yes
Tell me if you ear or see anything on the screen.
Sep 08, 2009 | Acer TravelMate 5520 Notebook
Yellow light flashes and Fan doesnt start
I think it may be a problem with the motherboard cause the power light should be green from what I remember. The fan isn't even turning on either which is very suspicious. Try another power supply if you have one handy and if that fails then the motherboard is bad. Even if your fan was bad, you would normally get video anyway before a warning message about the fan would come up.
May 08, 2009 | Dell Dimension E310 PC Desktop
W2686 eMachine doesnt turn on after changing powersupplies
hi im josh in cebu phils.may i help you? Friend if the pc does'nt power on even you have replace the power supply. it means that there is a major problem in your hardware definetly if not the power suppy the motherboard or the processor.be sure to have compatible mainboard and processor because there are mainboard that does'nt support a certain processor please try to check it .try to replace another motherboard that is compatible to your processor. or check the connection of the power on button and the wires from supply to motherboard.please do that to solve your problem hope i helped you good luck.
Feb 25, 2009 | E-Machines eMachines W2686 PC Desktop
Urgent
motherboard, power supply take your pick
Feb 19, 2008 | IBM ThinkPad A30 2652 Notebook
NO POWER
if it does not respond at all......i mean no fan no lights no anything.....then double check that your power supply is good.....if it is and you are sure your chasis connectors are placed on the proper pins then you could have a bad motherboard or cpu.......of course more troubleshooting should be attempted before drawing this conclusion (removing one part at a time, etc.) but no power is never a good thing.
Dec 11, 2007 | Gigabyte GA-8I945GZME-RH (0818313003041)...
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
222 people viewed this question
Clive
Clive
Alun Cox
