Question about Samsung DV448AEE Electric Dryer
Sumsung Eletric Dryer DV448AEP scratches on the door, can the door be replaced? Just bought it and the door is scratched. I got it at Sears Outlet, I can return it, but if there is no replacemnt available, I can not get one, and I just bought the matching Waher.
    President:
  • Samsung Master
  • 1,922 Answers
Call sears tell them to find you one now!!! or call the better business bureau and file a complaint...its new why should you have to replace anything at your expense....if you still want to buy the door go to appliance parts pros web site they can get you one or phone 1-877-477-7278
Posted on Oct 03, 2009
The outer skin on the freezer door is scratched. Is there an inexpensive fix to replace the outer skin on model 10651123210
If the scratch is on the smaller side and not a deep gouge, you should be able to obtain touch-up paint for the appliance. These products are usually available at Sears appliance parts depots or more generically at home improvement stores.
Jul 16, 2015 | Kenmore Refrigerators
When will there be a s sale on Samsung French door refrigerator
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Sears has a "Friends and Family Night", twice a year. You need a ticket to get. Contact: "Sears Customer Service". Also, Holiday week ends.
You may want to consider a "Sears Outlet (Scratch & Dent) Store". You can save several hundred dollars and get a one year warrantee.
Both Samsung and LG have the highest repair rate.
Also stay away from bottom freezers and units that have either the icemaker or the ice bucket mounted on the door.
Consider: GE, Kenmore, Kitchen Aid, Amada.
Mar 05, 2015 | Samsung RS2530BBP (25 cu ft) Side by Side...
My electric dryer worked fine yesterday, haven't had any problems. This morning I wen to push the button to start it and nothing. Model FER641FS0
Hello Pamela;
My name is peter. I am a retired field service appliance technician.
Your unit does not have a fuse. Every thing is built into your main control board.
First, lets see if we can reboot your appliance. Go to your breaker box and turn the power off to your appliance. Wait 10 minutes and turn the power back on to your appliance.
Do you have power?
Ok, no power. Then you have a main control board problem.
25419662-2wop33oc00rzrbarpm5t54vf-5-0.jpg Part #: 134086802 Cost: $135.00
This panel is easily replaced if you know someone who is good with tools.
If I were still working for Sears Home Services and cam to your home, I would leave you with about a $450.00 bill.
You may like to consider going to a "Sears Outlet Store" (Scratch and Dent). You can save several hundred dollars on a new unit and get a one year warrantee.
Feb 12, 2015 | Dryers
I have a bosch fridge freezer. i took the shelves out to clean them and left the door open. when i tried to replace them the walls had swollen at the rear and the shelves won't go back in....
Hello Richard;
You have cracks in the liner. Moisture has got behind the liner forming water, froze and expanded the wall.
This is not good. Your insulating material is now wet.
You can try turning your unit off, use a hair dryer, and push on the back wall to squeeze the water out, then seal the cracks with a high temp silicon adhesive.
It is near impossible to get all of the moisture out. Eventually you are going to end up purchasing a new unit.
When you purchase a new unit, consider going to a Sears Outlet (Scratch & Dent) Store. You can save $300-$400.00 and receive a one year warrantee.
Dec 23, 2014 | Bosch Refrigerators
Free download whatsapp
i am unable to download ur whatup apps
Oct 25, 2013 | iPhone Apps
How do replace heating element in dryer
Instructions
Things You'll Need:
* Volt meter
* Clean cloths
* Waste bin
* Replacement fuse (optional)
1. Secure the power cord in the Frigidaire dryer as well as the power outlet if the dryer does not start. Replace the fuse or reset the circuit breaker if necessary.
2. Check the fuse if there is power but no heat, as dryers need two fuses in order to operate properly. Replace the fuse if necessary. Select heated cycles if items are wet and cold after drying.
3. Open the dryer door and slide out the lint screen if the dryer seems to be taking a long time to operate. Clean off the lint and return the lint screen to the unit. Use a volt meter to check the power outlet for proper electricity, which should be 240 volts or more. Clean the exhaust hood outside the home and straighten the exhaust vent if bent.
4. Keep the load size medium and distribute pieces evenly inside the drum if items are wrinkled or damp. Increase drying time or temperature as necessary.
5. Check pockets for hard objects before putting pieces in the dryer, as items can create scratches or chips inside the drum and cause a clinking noise during use.
6. Contact Frigidaire for assistance if the problem continues.
Feb 24, 2011 | Frigidaire Electric Dryer
Dryer continues to run with door open
You need to replace the door switch,sometimes you can do this without removing the front panel,unplug the dryer and with a flat blade like a putty knife get behind the switch body and pry it out being careful not to scratch the paint,mark the wires on the switch and get a replacement
May 09, 2010 | Hotpoint NVL333EY Electric Dryer
Searching desperately for a good washer
You can check out outlet like sears or scratch and dent..(it there is one in your area) they come w/a 1yr warranty... where if you buy one from people you have to know what you are getting.. if you paid 150 for one w/no warranty.. the outlet I see them for around 250 for a deceit unit.. good luck..
Jan 21, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Samsung DV448AEE Electric Dryer Logo
157 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
