Question about HP LaserJet 2840 Printer
HP 2840 Ghost printing in the bkg?
Just installed new image drum and the first page was fine, but the second page printed the first page in the background (but lighter). What can I do?
  • 240 Answers
That is called ghosting. This is typically caused by a worn or fatigued component inside the imaging drum unit called the primary charge roller (PCR). It is a small black rubber roller. If you are careful and confident you can clean this yourself, otherwise the drum unit needs replacing.
Please read in full before attempting.
!Do not touch the imaging components with your hands or allow any foreign matter (i.e. grease) to touch them either!
To clean the PCR you have you remove it from the drum. It is held in place above the actual imaging drum, just above the drum shutter. On either side you will see two screws down in the cartridge that need to be removed. Once they are out you simply retract the imaging drum shutter and remove the plastic bar above the drum. The PCR is attached to this plastic bar. I would recommend cleaning the PCR in place so as to not disrupt the conductive lubricate that should be in place. Use a lightly dampened, with ONLY steam distilled water, lint free cloth and gently wipe and grime off. Repeat with a clean section of cloth until the PCR is an even dark color. COMPLETELY DRY BEFORE RE-INSTALLATION. Installation is the opposite of removal, a magnetic tipped screwdriver will help. Good luck and email with any questions.
Posted on Jan 14, 2010
  • 99 Answers
Need to replace the drive gear assy.
if you are a printer tech. would be easy but if not then take it to a printer replace shop.
Posted on Oct 03, 2009
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
Dec 02, 2011 | Ricoh Office Equipment & Supplies
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
My HP Laserjet 2840 is showing "replace supplies" in the display. There are 5 box/cylendar's that appear in the display and the last one has a solid black box box in it. I was able to go thru...
Thank you for contacting FixYa with your printer inquiry.
The low ink could definitely be the problem thats prompting the error. To begin troubleshooting print the supply status page and confirm the state of the various supplies. Follow the steps below:
Supplies Status page The Supplies Status page lists the remaining life of the HP print cartridges and the HP imaging drums. It also lists the estimated pages remaining, number of pages printed, and other supplies information. You can print a Supplies Status page from the device or the HP Toolbox. To print from the device, complete the following steps. 1. On the control panel menu, press MENU. 2. Use the button to select Reports, and then press ENTER 3. Use the button to select Supplies Status, and then press ENTER. Note Supplies information is also available through the HP Toolbox.
This page illustrates conditions of consumables for Toner Cartridges, Image Drums, Image Transfer Kits, and Fuser Kits. It also provides ordering information and methods for disposing of or recycling used supplies.
Areas of Supply Status Page: 1. Print-cartridge area. This area contains a section for each of the print cartridges and provides information about HP print cartridges. This information includes the part number for each print cartridge, whether each print cartridge is low, and the life remaining for each print cartridge expressed as a percentage, as a graphic, and as the estimated number of pages remaining. This information might not be provided for non- HP supplies. In some cases, if a non-HP supply is installed, an alert message appears instead. 2. Imaging-drum area. This area contains the same information for the imaging drum that the print-cartridge area provides for the print cartridges. 3. Warranty Note. This section contains information about how the device warranty is affected when you use non-HP supplies. It also requests that you call the HP fraud hotline if a supply that is being detected as a non-HP supply was sold to you as a genuine HP supply. (See HP fraud hotline.) 4. Ordering Information. This section contains basic information about how to order new HP supplies. See Checking status and ordering supplies. 5. Recycling Information. This section contains a link to the website that you can visit for information about recycling. See Replacing and recycling supplies.
The product Support Manual is available from the below link:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00341096/c00341096.pdf
If you have further questions just add comment to this link and we will gladly provide additional information and support.
Kind regards,
TF
Jun 08, 2011 | HP LaserJet 2840 Printer
Only right side of the page prints - help!
Marks repeatedly appear at even intervals on the unprinted side of the page.
c00366165.gif Internal parts might have toner on them. The problem typically corrects itself after a few more pages. The paper path might need cleaning. Click here to go to the Print Defect ruler for more information.
Clean the device. The imaging drum might be low. Click here to go to the Print Defect ruler for more information.
Replace the imaging drum. The fuser might be damaged. Click here to go to the Print Defect ruler for more information.
Contact HP Customer Care Marks repeatedly appear at even intervals on the unprinted side of the page.
Contact HP Customer Care hi at the link given below, click on it and locate the page (halfway down) where it states this
Contact HP Customer Carehttp://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=ca&taskId=110&prodSeriesId=445194&prodTypeId=18972&prodSeriesId=445194&objectID=c00366102
Nov 04, 2010 | HP LaserJet 2840 Printer
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Feb 25, 2009 | HP LaserJet 2840 Printer
MFC-7420 GHOST IMAGES
sounds like a bad drumbur also can be caused by a defective fuser.
Jan 16, 2009 | HP LaserJet 1020 Printer
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
For Flexer and Guest - The Imaging Drum Assy is the 5-th consumable for your printer. U can buy it as well as any toner cartridge. U can find it in the front of the 4 toner carousel with a green plastic cover. Push it to the back of the printer and pull it out straight up. The new one has orange stripes and plastics that you should remove. The Imaging Drum's life is about 20k pages (black with 5% coverage) and 5k page (colour 15% coverage)
Dec 20, 2007 | HP LaserJet 2840 Printer
Ghost images
Is it from the most recently printed page, or is it the same image avery time regardless of what you print? It sounds like your drum or roller (I'm not sure about the exqact term in english) might be the issue. Have you somehow managed to "force" a printing without paper in the printer?
May 18, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 2840 Printer Logo
374 people viewed this question
Seeker5211
Seeker5211
